Thread: Some more top swap questions! Yay!
Page 21 of 71 FirstFirst ... 11192021222331 ... LastLast
Results 401 to 420 of 1411
  1. #401 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by suitercrew View Post
    I do have the stand and its 3 bolts the gp was a 97 hopefully its all the same. Arent the studs on the l36 the same or is it an extra stud? I know the lim bolts are the same but i didnt know if the uim bolts are the same. Im missing a couple of those as well
    Sent from my LG-D851 using Tapatalk
    UIM bolts are indeed different. And the idler stand and 3 bolts will fit just fine.
  2. #402 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Blahh well atleast i feel better about not driving for an hr just for one bolt lmao
  3. #403 Re: Some more top swap questions! Yay!
    leave gf in the car lol dont rush me!!!!!
    maybe make a list of what you have already. then we can fill you in on whats missing.
  4. #404 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok so for starters i have all new gaskets from the heads up also two bottles of sc oil. As far as hard parts go i have
    Fuel rails
    Sc
    Tb ( all sensors, do not have bolts im pretty sure there the same as l36)
    Injectors
    Lim
    Vc
    Complete heads (minus the 1.9s im still trying to find)
    Hb
    Coil pack bracket
    All sc belt idler and tensioner pulleys minus the tensioner bolt
    New l67 map wiring with map ( still havent figured out which colors need to be spliced together)
    Sd headers(still waiting on band clamps)
    Front o2 extension harness
    New rocker bolts
    New head bolts
    *gasps for air*
    Ok i think thats everything i have.
    So from what i know i will need:
    Sc tensioner bolt
    Possibly tensioner stud?
    New oil and coolant
    Sc belt
    Sc bolts
    Get the whole vaccum wiring set
    Tuned pcm
  5. #405 Re: Some more top swap questions! Yay!
    Oct 2015
    Oo i got some autolite 104s as well
  6. #406 Re: Some more top swap questions! Yay!
    did i miss the balancer?
    id grab them tb nuts too. just to be safe..
  7. #407 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    Quote Originally Posted by Wrongdoggs View Post
    you missed it, I saw it
  8. #408 Re: Some more top swap questions! Yay!
    Oct 2015
    I have the harmonic balancer yes
  9. #409 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Do you have the crank pulley puller? You can use a stud from the L36 coil bracket for the SC tensioner. Take a normal nut from your dog bones and grind the lip down (or the built in washer on the nut) a little it'll work fine for the SC tensioner.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  10. #410 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I'd recommend getting a set of ARP header bolts they are really nice instead of those factory studs.
  11. #411 Re: Some more top swap questions! Yay!
    Oct 2015
    I dont have the puller i figured i would be able to rent one at autozone or somewhere. I need my dog bone haha. Ill just get the bolt from the jy since i need to go back there anyway but thanks for the tip!
  12. #412 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    The parts store doest have anything like that even my local motor shop that did my machining on the block had to borrow one from the dealership. I ended up buying one online when I top swapped and went with the SFI crank pulley.
  13. #413 Re: Some more top swap questions! Yay!
    Oct 2015
    Whats the difference in crank pulleys besides a lot of money haha? Ill check around if i cant find one are you looking to sell yours?
  14. #414 Re: Some more top swap questions! Yay!
    you need three bolts M6 x 1.00 and 70-75mm in length.
    and this style puller
  15. #415 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    The crank pulley reduces vibration it weighs more then stock, it helps when your reving higher over 6,000rpm and it allows you to use a 8 rib belt for when you use smaller pulleys and a 8 rib belt just looKS better in my opinion lol I'm not sure about the pulley puller I'll probably need it someday I'm always doing things to my car I'd probably let you borrow it if you can't get one.
  16. #416 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya i dont plan on revving to high im not sure what would even be recomended for stock valvetrain minus 90# springs and 1.9s. It looks like zzp has a kit for 40$ does that work?
  17. #417 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    $40 bucks at zzp for what? The crank pulley puller?
  18. #418 Re: Some more top swap questions! Yay!
    Oct 2015
    Yes sir http://zzperformance.com/3800/pulley...er-puller.html
  19. #419 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Yupp that'll work
  20. #420 Re: Some more top swap questions! Yay!
    Oct 2015
    Nice well if its only 40 $ ill just buy the darn thing. Quick question though the hb i have i got for free and it doesnt look to be in to great of shape ( cracks in the rubber) i think amazon has new ones for about 65$. Should i just get a new one?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
