Thread: Some more top swap questions! Yay!
Page 15 of 71 FirstFirst ... 513141516172565 ... LastLast
Results 281 to 300 of 1411
  1. #281 Re: Some more top swap questions! Yay!
    till they look smooth. your only doing light pressure, its not like you can grind em to nothing, unless the pitting is that deep.
    even the valve seats were pitted up some.
    before.
    after
  2. #282 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    before.
    after
    That looks damn good.
  3. #283 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    This us what i got
    Sent from my LG-D851 using Tapatalk
  4. #284 Re: Some more top swap questions! Yay!
    one more time then. its close.
  5. #285 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks scotty i gotta go to work ill update with more pictures later!
  6. #286 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    I paid 150 bucks for a shop to do my heads I have on now to get a valve job like that, and you did it yourself. good job.
  7. #287 Re: Some more top swap questions! Yay!
    Oct 2015
    Hey quick question im about to buy my sd headers is there any difference in the ones they have on ebay and the ones on their website?
  8. #288 Re: Some more top swap questions! Yay!
    Probably just the price
    04 Comp G.
  9. #289 Re: Some more top swap questions! Yay!
    Oct 2015
    Also im buying all my bolts and gaskets right now do i need a new crankbolt? I didnt think so but noticed zzp had it in there top swap gasket kit
  10. #290 Re: Some more top swap questions! Yay!
    re use the crank bolt.
  11. #291 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks everybodyy!!
  12. #292 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok so im getting my heads put back together minus the 1.9 rockers im still trying to find. I got felpro valve seals and im confused if im supposed to take the metal rings off to install them or just force it on?
  13. #293 Re: Some more top swap questions! Yay!
    Kemmerer, Wyoming
    force it on.
  14. #294 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks
  15. #295 Re: Some more top swap questions! Yay!
    yup, just push em on. if you got felpros mine came with a plastic condom to cover the locks so the seal slides past them smoothly and dont tear the seal up.
    you can also use like a 10 mm deep socket to push them all the way down.
  16. #296 Re: Some more top swap questions! Yay!
    Oct 2015
    Well im just having trouble getting them over the valve guide's
  17. #297 Re: Some more top swap questions! Yay!
    a thumb on both sides and push down. they are tight. why the socket helps, you can tap em on and down all the way.
  18. #298 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks scotty
  19. #299 Re: Some more top swap questions! Yay!
    if you got a 3/8 drive 10 mm, put the ratchet side down, so its a flat area pushing the seal down.
  20. #300 Re: Some more top swap questions! Yay!
    Oct 2015
    Will doo!
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
