Thread: Some more top swap questions! Yay!
Page 12 of 71 FirstFirst ... 210111213142262 ... LastLast
Results 221 to 240 of 1411
  1. #221 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ahhh!! Its so confusing. Ok so the l36 block has those three bolts that hold that stand on correct?
    Sent from my LG-D851 using Tapatalk
  2. #222 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    the ones that fit the holes in the block.
    No, I meant the head size. I need to know what tools to bring to the JY. I wanna say 13mm.
  3. #223 Re: Some more top swap questions! Yay!
    no idea how the l36 bracket bolts on.
    you need the nut for that stud too. it holds the tensioner on. and the two bolts for the bracket
  4. #224 Re: Some more top swap questions! Yay!
    Quote Originally Posted by CelibateHalibut View Post
    i wanna say 10 mm.
  5. #225 Re: Some more top swap questions! Yay!
    that bolt for the pulley on the stand maybe a 15 mm, or a t55 torx bit. the pulley needs to come off to get to the stands bolts.
  6. #226 Re: Some more top swap questions! Yay!
    Apr 2015
    What's the best way in your opinion to get the bolt out without the pulley spinning? I don't think the belt is still on the car(s) I have in mind.
  7. #227 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok im sorry scotty i hope im not driving you insane but this is just really confusing for me. So if im understanding right the two bolt holes on the top of the coil bracket are where the studs slide in then the tensioner goes on the inside stud then gets bolted down. The bottom outside bolt hole is for another pulley that just gets bolted down and then from there i have no idea especially with the #9 pulley i. The picture
  8. #228 Re: Some more top swap questions! Yay!
    Oct 2015
    This is all i have obviously ill need the pulleys themselves but what else am i missing?
  9. #229 Re: Some more top swap questions! Yay!
    this is the best pi i have. i used to have two studs, now only one. and i used a bolt on the lower hole.
    the tensioner needs a thin walled 13 mm deep socket. a 12 point socket seems to fit best.
    the missing idler pulley you need the bolt for it too, it goes into the bracket on that bottom part thats sticking up.
    you can see how the tensioner should look too.
    pulley bolts all come off, they all bolt into something, pulley spins free all the time on a bearing. all bolts are normal threads too, not reverse threads.
  10. #230 Re: Some more top swap questions! Yay!
    Donating Users timboku's Avatar
    Montgomery, IL
    Hope you have the nut as well for that tensioner..it's a one off thin wall nut..
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  11. #231 Re: Some more top swap questions! Yay!
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    yeah you'll have to get that nut from a junkyard if you dont have it
    2000 GT Mods: HAI, 10.5mm wires, rebuilt 60k motor, ZZP stainless headers, magnaflow mufflers, fresh paint job,L-67 top swap, Ported SC...
  12. #232 Re: Some more top swap questions! Yay!
    Oct 2015
    Yeah well i dont have it but i figured tomorows my day off im just going to run around town looking for some l67 that arent totally destroyed and that way i can see it and grab what i need in person
  13. #233 Re: Some more top swap questions! Yay!
    that stud comes out with a 4.5 or a 5.5 mm socket. iirc. tiny little hex on the end of the stud.
  14. #234 Re: Some more top swap questions! Yay!
    Oct 2015
    I should have that in my tools
  15. #235 Re: Some more top swap questions! Yay!
    Oct 2015
    So the last question i have is the pulley that is underneath the water pump and tensioner how does it bolt to the block cause its not on the coil brack or heads?
  16. #236 Re: Some more top swap questions! Yay!
    same deal on the two head studs ones on the out side of both exhaust manifolds. little 4.5 socket to get em out.
  17. #237 Re: Some more top swap questions! Yay!
    Quote Originally Posted by suitercrew View Post
    thats the one you need the stand for.
  18. #238 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya i know that i need the stand but that stand bolts to the l36 block? Or where?
  19. #239 Re: Some more top swap questions! Yay!
    go back and re read your thread here, its been covered, pics even.
  20. #240 Re: Some more top swap questions! Yay!
    Oct 2015
    You said the two bolts right under the water pump inlet correct?
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
