Thread: 04 grand prix
Results 1 to 16 of 16
  1. #1 04 grand prix
    May 2012
    Canada , Sarnia
    Winter is here and my hot air takes a while for it to get hot I know there is air in the system because my upper coolant line came off 2 months ago I want to do a flush to get the trapped air out how hard is it to do on my car ?
  2. #2 Re: 04 grand prix
    Grab a dictionary and look up the word "Easy", that should explain it pretty well.
    A short and too the point flush would be remove both rad hoses, both heater core hoses and remove the thermostat. Take a hose and spray water through the rad, into the intake manifold and through one heater core hose/then the other. Slap it back together, fill through the thermostat hole and rad, then install thermostat and start it up and let it run. It should bleed just fine with the cap off.
  3. #3 Re: 04 grand prix
    May 2012
    Canada , Sarnia
    ok thanks going to do the flush tomorrow
  4. #4 Re: 04 grand prix
    May 2012
    Canada , Sarnia
    did the flush didnt take to long another question my passenger floor is always wet could the ac drain line be clogged and if so do you know the location of it
  5. #5 Re: 04 grand prix
    GXP Level Member
    Mar 2015
    Tomball
    Right here:
  6. #6 Re: 04 grand prix
    May 2012
    Canada , Sarnia
    jacked up the passenger side tonight and took off the wheel and seen the little rubber elbow can i get to this from the top tryed to get it with the wheel off no luck ??
  7. #7 Re: 04 grand prix
    GXP Level Member
    Mar 2015
    Tomball
    You ain't going to you have to come up between the subframe
  8. #8 Re: 04 grand prix
    May 2012
    Canada , Sarnia
    OK thanks
  9. #9 Re: 04 grand prix
    Apr 2011
    Elk Rapids, Michigan
    Wet passenger side floor is usually caused by water dripping in from the cowl. You can get an updated part from the dealer, Amazon or eBay for around $10 and it takes 20 minutes to replace if you're slow. There are a couple of write ups on here, I believe in the "how to" section.
    2001 black GTP coupe, Gen V, ZZP S2IC & billet fuel rails, XP cam, LS7 lifters, 105# springs, ZZP MPS w/3.4 pulley, Northstar tb, LQ4 maf, ZZP headers, K & N CAI, Meziere electric wp, Caspers fp retire, F body front brakes, GMPP strut braces​, Don Rome strut brace mounts.
  10. #10 Re: 04 grand prix
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    The sooner it's taken care of the better because it goes through your blower motor. Mine did same thing 8 months later blower motor eats sh!t
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  11. #11 Re: 04 grand prix
    May 2012
    Canada , Sarnia
    Is this what your talking about the deflector #15794785 I just did that last week
  12. #12 Re: 04 grand prix
    Apr 2011
    Yes, that should have fixed the wet carpet on the passenger side. Some recommend that you also replace the blower motor/fan assembly as well since water has been running through it.
  13. #13 Re: 04 grand prix
    May 2012
    Canada , Sarnia
    the carpet is fine now just damp and would the blower motor/fan be going in the car sometimes dosent work till i hit a bump then turns back on and roughly how much is the blower motor and fan ?
  14. #14 Re: 04 grand prix
    Nov 2012
    Madison
    Quote Originally Posted by gordster1122 View Post
    40 on Amazon
    check rock auto
  15. #15 Re: 04 grand prix
    May 2012
    Canada , Sarnia
    do i need a new resistor to ????
  16. #16 Re: 04 grand prix
    Nov 2012
    Madison
    I replaced that first and it was the blower. I just left it in for world peace.
    I bought the TYC from Amazon. It has a strange whine that elevates with speed. Works fine.
    The Delco I believe from RA is about 80 and no doubt would be whisper level like the OEM.
    Do one at time if you dont care and find out which is the problem. My blower would start fine but then slowly slow down after it got hot.
    Getting water on it in the past didn't help the motor much. The resistor is pretty much out of the water path.
  1. 2004 Grand Prix Comp GTP Rear Fenders/Quarters and Grand Prix Parts***
    By luckydogaroo in forum General Grand Prix Discussion
    Last Post: 01-30-2015, 04:00 PM
  2. Replies: 23
    Last Post: 06-21-2013, 12:52 PM
  3. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  4. 1991 grand prix 3.1 swap into 1996 grand prix 3.1
