Thread: Replaced Hub still slight hum
Results 1 to 9 of 9
  1. #1 Replaced Hub still slight hum
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I changed my HUB with a cheap one, it started humming on the highway almost immediately. I replaced it today with an AC Delco hub. The Humming got much quieter but its still there (it changed pitch though).
    i didnt use a torque wrench on the axle nut. Could i have over tightened the axle nut with the impact?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: Replaced Hub still slight hum
    Apr 2015
    It could also just be your tires.
  3. #3 Re: Replaced Hub still slight hum
    Sep 2014
    Richmond Virginia
    I did buy the cheapest ones i could find lol
  4. #4 Re: Replaced Hub still slight hum
    SWPA
    You don't use an impact to tighten, especially important things, because as you know, you don't know how tight you got it. I highly doubt you got it too tight though.
    You learned your lesson on why you don't use a cheap bearing too.
  5. #5 Re: Replaced Hub still slight hum
    Apr 2015
    Quote Originally Posted by 04lss View Post
    Lol. Tires on my wife's car hum on her gp. My g6 it has firestone affinity on it and no hum
  6. #6 Re: Replaced Hub still slight hum
    Sep 2014
    Richmond Virginia
  7. #7 Re: Replaced Hub still slight hum
    Sep 2014
    Richmond Virginia
    whats the torque on an axle nut supposed to be on one of these?
  8. #8 Re: Replaced Hub still slight hum
    118 ft lbs.
    You'd have to go extremely tight to **** up one of these bearings, they bearings dont really require a certain number to like preload them like pressed in bearings.
  9. #9 Re: Replaced Hub still slight hum
    Sep 2014
    Richmond Virginia
    Ill swap the tire tomorrow, and see if the sound moves.
  1. Slight rpm surge between 3rd and 4th ?
    By mickyb37 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2013, 09:17 AM
  2. Slight lift
    By LowRidinCrew in forum General Grand Prix Discussion
    Last Post: 07-15-2013, 07:39 PM
  3. Slight upgrade
    By ajoliver2010 in forum Brakes/Suspension/Chassis
    Last Post: 08-30-2012, 08:07 AM
  4. Slight Vibration
    By chevyy1212 in forum Brakes/Suspension/Chassis
    Last Post: 06-25-2012, 10:05 AM
  5. Slight vibration.........
    By Texas Bullet in forum General Tech Discussion
    Last Post: 12-31-2010, 04:54 PM
