Thread: service engine light
Results 1 to 8 of 8
  1. #1 service engine light
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Service engine light comes on intermittently but once i ture the car off then back on the light goes out. Its the light far left of the cluster. Not the check engine light(checked codes anyway, none).
    I thought maybe it had something to with the ABS or something(no ABS/traction light though)
    Wierd bc sometimes the service light will come on if i turn the hazard lights on, not sure if its related or just a coincidence that the service light came on when i used the hazards lights.
    Maybe a service interval or something? Any help would be appreciated
    00' Regal GS
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: service engine light
    You mean the service vehicle soon light, Regal guy!
    I don't believe it comes on for service intervals, but check your oil life just in case and reset it if it's at 0%. It shouldn't come on alone for the ABS, the ABS light would come on too.
  3. #3 Re: service engine light
    Jul 2012
    North Philly
    Oil life is at 87% , yeah i meant service vehical soon. Y else would it come on intermittently?
  4. #4 Re: service engine light
    it turns on with the abs, or air bag lights. or any other body related reason, best to have it scanned. it will have stored codes for each time its come on.
    the parts store scanner wont work for this most of the time, these are U and C codes.
  5. #5 Re: service engine light
    Jul 2012
    North Philly
    Abs never comes on, airbag is intermittent as always. Must be U & C codes bc my scanner wont pick it up either. I have a Snap On scanner at the shop ill see if that picks it up.
    Weird....
  6. #6 Re: service engine light
    its gonna show lots of air bag codes. snap on scanner should work fine, ive used it myself on my car before.
    air bag could as simple as a dirty plug under the seat, or under the dash by the obd2 port. any yellow plugs are airbag related. also the airbag module under the pass seat could be corroded and not grounding to the floor. if your cowl ever leaked id look at the air bag module for sure.
  7. #7 Re: service engine light
    Jul 2012
    North Philly
    Whats the cowl(this is new terminology to me bc im thinking the hood)?
  8. #8 Re: service engine light
    the thing that leaks and lets water leak on the pass side floor board. its under the windshield cowl. you need to take it off to change the cabin filter. that thing.
  1. service engine light -_-
    By nickgpgt in forum General Grand Prix Discussion
    Last Post: 06-03-2013, 04:12 PM
  2. Service Engine Light came on
    By jwjones in forum General Tech Discussion
    Last Post: 01-03-2012, 02:41 PM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. Service engine soon light
    By the955iman in forum General Tech Discussion
    Last Post: 02-15-2009, 01:21 PM
