Thread: calling all smart people.... random engine cutting out
Results 1 to 7 of 7
  1. #1 calling all smart people.... random engine cutting out
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    2002 GTX twincharged etc etc. engine has a random ign cut out issue. completely random. sometimes its within 3 min of starting and driving, sometimes takes an hour or more. it skips, cuts out, sputters. it will start to skip, if you give it wot, its flat, like nothing is there. if you ease the throttle in, it skips and pops. it often will clear up after doing its weird thing. but will happen again at another random time.
    NEW ac delco crank position sensor, new plugs, new wires, new coils, swapped out ICM, swapped out ICM harness. its not heat related, as it happens whether engine is hot or cold. have the big 3 upgrade. im at a loss.
    any input appreciated.
  2. #2 Re: calling all smart people.... random engine cutting out
    Could be a bad wire somewhere in the engine harness between the icm harness and the pcm.
  3. #3 Re: calling all smart people.... random engine cutting out
    Nov 2011
    NY
    Why new CPS? And I agree, if not something vacuum related, then maybe an almost completely broken or melted wire in harness. But I'm assuming you've ran through some basics and ruled out Maf, vac, etc. My SE had similar issue, thought it was CPS but wound up being a melted wire in the harness... Intermittent stuff like that can be a PIA for sure. But hope you find the problem!
  4. #4 Re: calling all smart people.... random engine cutting out
    Problem is between the steering wheel and seat.
    Have you ruled out the maf? If it's screwing up, that could cause fueling issues which could do most of what you describe. If you know which is missing spark or fuel, that might help narrow it down.
  5. #5 Re: calling all smart people.... random engine cutting out
    Nov 2011
    NY
    Brutal...
  6. #6 Re: calling all smart people.... random engine cutting out
    Quote Originally Posted by coolone View Post
    Brutal...
    Or honest.. heck I could have said it was the Snowflake tune....or lack of. Would you guys like that better?
  7. #7 Re: calling all smart people.... random engine cutting out
    Feb 2013
    37.295091, -121.930053
    i would have called him a dumbass for even touching his car but thats just me. Chances are bill is right
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  1. Engine 'cuts out' when i pass people?
    By missboosted in forum Introductions/Noob Questions
    Last Post: 05-29-2015, 05:44 PM
  2. 97 Grand Prix Engine Randomly Cutting Out
    By jpearsall187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2014, 02:57 PM
  3. engine question for you expiernced techs/machinest/smart people
    By joe0813 in forum General Tech Discussion
    Last Post: 12-21-2012, 03:19 PM
  4. Quiz Time, lets see if you people's are as smart as you act
    By dpzelenak in forum Off Topic Discussion
    Last Post: 10-02-2011, 10:53 AM
  5. anyone smart on abs???
    By schmitt in forum General Tech Discussion
    Last Post: 06-12-2011, 09:37 AM
