Thread: Will KYB Adjustable struts fix my problem? 245/45/18 tire
Results 1 to 20 of 25
  1. #1 Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Feb 2015
    california
    I have just gotten 18 inch saleen wheels 18x9 with 245/45/18 tire and pretty much only rub on freeway bumps. Im not sure my existing struts are going bad but i notice my car does have a bit more bounce than say the 98 buick lesabre my buddy has thats even older than my 2002 grand prix. Would the KYB adjustable struts in the rear atleast help keep the tires from rubbing that plate on the spring strut assembly?
  2. #2 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Feb 2015
    california
    or what about these rear heightening springs? http://www.wbodystore.com/suspension...g-springs.html
    Might work better?
  3. #3 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Aug 2013
    McDonald PA
    Could just roll your fenders. Or do you know it's rubbing on the top mount which would be kinda insane.
  4. #4 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Antioch, IL
    the plate moves with the tire, the spring is ABOVE that plate, it cannot hit your tire on bumps
    2009 Challenger SRT8
    Expert at being gay.
  5. #5 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Feb 2015
    california
    so what am i rubbing against? the wheel well? Should I roll the fenders? Would the adjustable struts help or heightening springs help?
  6. #6 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    likely the offset is too far out on the saleens. Sure a lot of people have run those wheels but you need to roll the fender lip. should be pretty easy to see where its rubbing on both the tire and the tops of the fender lips.
    also the 245/45/18s is what most people run.
  7. #7 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Dec 2013
    ohio
    Saw a thing called cable mod. Late night can't remember where but you cable strap your rear struts somehow. Not sure how this would effect handling.
  8. #8 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Nov 2013
    Wisconsin!
    ^don't do that. That's for the strip only to help keep weight transfer to the rear as little as possible.
  9. #9 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Roll your fenders in the rear. Problem solved!
    04 Comp G.
  10. #10 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    roll the fenders.
    an adjustable strut won't stop the spring from being too soft to keep the tires out of the fenders. and raising the rear is going to look terrible. i hope the car is lowered already or i guarantee it looks like poop as it is.
  11. #11 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Feb 2015
    california
    roll the fenders.
    Car is not lowered does not look too bad
  12. #12 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Changing the strut isn't going to help you.
    Roll the fenders.
    Do it right the first time, or go to a thinner wheel.
  13. #13 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    my lord look at all that air between the tires and fender. my eyes are burning from the gap.
  14. #14 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Feb 2015
    california
    theres some gap in front but should be no different than stock...
  15. #15 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    optical illusion created by larger diameter wheels. doesn't make it any better knowing that, though.
  16. #16 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Feb 2015
    california
    So anyways guys... roll the fenders? got it.
  17. #17 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
  18. #18 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Feb 2015
    california
    that's most likely your problem. only in the rear.
    So I did a test with my friend. We tried to bounce the rear of the grand prix to see where it is rubbing and as hard as we bounced it we could not see any touching of tire and fender. You can see in the pictures i have a at least a good inch and a half probably two inch gap from tire to fender in back. Is it possible our weight bouncing the car doesnt even come close to freeway 70mph bumping? Could I be rubbing something else? Anyone have this size mustang wheel with this tire size who can help?
  19. #19 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Dec 2008
    Lawndale, CA
    There is a lip on the inner rear fenders. You can feel it with your hands. Roll that part and be done.
    Car is asking to be lowered.
  20. #20 Re: Will KYB Adjustable struts fix my problem? 245/45/18 tire
    Feb 2015
    california
    Quote Originally Posted by The Guz View Post
    Lowering will help the car not rub? And wouldnt I would have seen that lip touching the tire when i bounced the back? Quite a pricey job to not really know for sure...
  1. KYB AGX Adjustable Struts
    By rvnwlf in forum Brakes/Suspension/Chassis
    Last Post: 05-27-2012, 10:41 PM
  2. Problem installing new front struts
    By Mnasrv in forum General Tech Discussion
    Last Post: 12-29-2011, 03:32 PM
  3. the problem is tires or struts??
    By spider4 in forum General Tech Discussion
    Last Post: 11-19-2011, 02:48 PM
