Thread: 180 T-Stat
Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 196
  1. #61 Re: 180 T-Stat
    Enfield, CT
    Quote Originally Posted by RickyBobby03 View Post
    Hey guys. I just removed my t stat all together and my motor runs so much cooler now. The fans don't even have to run which means moar power
    Hmmm enjoy over-cooling your engine.
    Sent from my LG G3
  2. #62 Re: 180 T-Stat
    some older shots of my temps before the tune.
  3. #63 Re: 180 T-Stat
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    KR, knock retard, is the computer pulling timing to PREVENT knock/detonation. let's not confuse people, here.
    it's our way of knowing that knock is occurring, but one KR is shown it's already happened.
    Now I thought the knock was push rod related, but it's not? It's premature detonation? And how does it happen or when does it start?
  4. #64 Re: 180 T-Stat
    Buffalo
    Quote Originally Posted by HighOctaneRacing View Post
    Sent from my LG G3
    It's soo cold my knock sensors never come on , even more power
  5. #65 Re: 180 T-Stat
    Quote Originally Posted by 01Grand PrixGT View Post
    when i was stock it started at 3200 rpm and built like mad all the way through the rpms up to 8*kr. dropping my timing to like 6* and the car would pretty much fall on its face.
    every car is a bit different tho. some cars have very little kr stock, others like mine were kr monsters. rockers and a u bend delete took all the kr away too. then it pulled damn good, cause no more kr and no more timing being pulled. <<<<still on the stock tune mind you.
  6. #66 Re: 180 T-Stat
    it happens when the cylinders are too hot, or cylinder pressures too high, and the fuel ignites prior to the spark plug igniting. this will push down on the piston as it's traveling up. this causes damage on a number of levels.
    the real cause of the pistons chipping is the upper ring gap closes up and lops off the corner of the piston. it always happens in the same spot for everyone that's done it.
    KR is just a way for us to know that detonation is occurring and that we need to deal with it in some form, whether it be fuel, timing, or air related.
  7. #67 Re: 180 T-Stat
    Buffalo
    Hey Scott on a serious note, why is your intake temp soo damn high?
  8. #68 Re: 180 T-Stat
    hot ass day bob. how you like the ltft? lol -15 parked, nice factory tune. you can see how much cooler my trans is too from the pic on the last page.
  9. #69 Re: 180 T-Stat
    Buffalo
    We gotta get you set up with a FWI
  10. #70 Re: 180 T-Stat
    hai for life man lol
  11. #71 Re: 180 T-Stat
    Apr 2015
    How do you check for KR then? Like what did Scotty use?
  12. #72 Re: 180 T-Stat
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    torque pro app for android. your NA so there's no need for you to worry about it.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  13. #73 Re: 180 T-Stat
    thats the toque app. you need a bletooth obd2 scanner and a droid os in a phone or tablet.
    costs less than 20 bucks. 5 for the app, 10 to 15 for most obd2 scanner. im using the elm 327
    i got this one, but this one sold from china, will take for ever to get to you. see how its th elarge one and it says advance obd scan tool the mini's dont seem to work well and dont say that on it.
    theres other too guys have found to work well as well. but they seem to cost up to 20 bucks.
    http://www.ebay.com/itm/Auto-ELM327-...303773&vxp=mtr
  14. #74 Re: 180 T-Stat
    Buffalo
    Lmao n/a knocked worse then my GS did
  15. #75 Re: 180 T-Stat
    n/a engines have KR too, but it means nothing with out a boosted application.
  16. #76 Re: 180 T-Stat
    Apr 2015
    knock RETARD
    Why can't you ever be nice to me!!?? :'(
  17. #77 Re: 180 T-Stat
    Buffalo
    Here's a kitten
  18. #78 Re: 180 T-Stat
    GXP Level Member
    Mar 2015
    Tomball
    You can't say no to that...
  19. #79 Re: 180 T-Stat
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    i found two dead cats in back yard last night my hunting dog caught them snapped there necks and pilled them at the back door for me
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  20. #80 Re: 180 T-Stat
    Apr 2015
    I hate cats so I have no problem saying "No" to that!
  1. T Stat Help
    By illtacticz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2011, 08:13 PM
  2. 180 vs 195 t'stat on 3.4
    By Teardrop in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-09-2010, 06:47 PM
  3. 180 stat
    Last Post: 07-12-2009, 08:41 AM
  4. 180 T-Stat
    By xerxescct in forum General Tech Discussion
    Last Post: 07-08-2009, 11:19 AM
  5. t-stat ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 04-29-2008, 11:30 AM
