I have a 2008 GP Base and for some reason both my low beams are not working at all. I changed the fuses and nothing, high beams and the parking lights work fine. I turn the dial to off and it tells me headlights suggested perfect turn it back on and nothing no go. Anything else I should check other than the fuse? The fuse for the low beams are located under the hood. Also want to mentioned I took out a light bulb and it still looks brand new on both sides.
