Thread: Help with Low beam headlights both sides not working on GP 2008
Results 1 to 9 of 9
  1. #1 Help with Low beam headlights both sides not working on GP 2008
    Mar 2013
    Canada
    I have a 2008 GP Base and for some reason both my low beams are not working at all. I changed the fuses and nothing, high beams and the parking lights work fine. I turn the dial to off and it tells me headlights suggested perfect turn it back on and nothing no go. Anything else I should check other than the fuse? The fuse for the low beams are located under the hood. Also want to mentioned I took out a light bulb and it still looks brand new on both sides.
  2. #2 Re: Help with Low beam headlights both sides not working on GP 2008
    Mar 2013
    Canada
    Can it be this relay? If so how can check to see if it is? http://www.amazon.ca/ACDelco-1501674.../dp/B0065S6S8Y
  3. #3 Re: Help with Low beam headlights both sides not working on GP 2008
    Look for the HDM module in the fuse block. It should be like a 5 pin relay, that is normally the cause for both headlights to go out at the same time.
  4. #4 Re: Help with Low beam headlights both sides not working on GP 2008
    Mar 2013
    Canada
    Yes I believe it's number 35 it seems like, trying to find a shop within Canada so I get it pretty fast. Assuming that is the issue.
    Sent from my SGH-I337M using Tapatalk
  5. #5 Re: Help with Low beam headlights both sides not working on GP 2008
    SWPA
    First try to just pull the relay out and reseat it. My low beams went out all of a sudden while I was driving. I pulled the relay and reseated it and haven't had an issue since.
  6. #6 Re: Help with Low beam headlights both sides not working on GP 2008
    Mar 2013
    Canada
    Just tried that no go
  7. #7 Re: Help with Low beam headlights both sides not working on GP 2008
    Mar 2013
    Canada
    Replaced the relay switch lights work again thanks
  8. #8 Re: Help with Low beam headlights both sides not working on GP 2008
    So the number 35 relay was the issue?
  9. #9 Re: Help with Low beam headlights both sides not working on GP 2008
    Mar 2013
    Canada
    Yes sir, replaced it and lights were working again
  1. Having a problem with 2008 GXP 5.3L Low Beam Headlight Socket. Help??
    By arod812 in forum General Tech Discussion
    Last Post: 12-25-2014, 01:24 AM
  2. Headlamps low beam not working.
    By jdcowboy in forum General Grand Prix Discussion
    Last Post: 11-12-2012, 03:36 PM
  3. low beam headlights not working
    By beaver in forum Introductions/Noob Questions
    Last Post: 11-01-2012, 01:05 PM
  4. Low Beam headlights
    By GP_Kid18 in forum General Tech Discussion
    Last Post: 02-28-2011, 08:33 PM
