Thread: subframe mount interchange
Results 1 to 15 of 15
  1. #1 subframe mount interchange
    Arizona
    Curious if anyone knows rather all aluminum subframe mounts rather it'd be for a impala grand prix etc... can be changed. I'm looking into utilizing 9c1 impala subframe mounts on my gxp. Gxp lists as sport mounts but the only firm ones are for the impala.
  2. #2 Re: subframe mount interchange
    Arizona
    Bump
  3. #3 Re: subframe mount interchange
    Arizona
    So incase anyone cares, yes gxp mounts are the same diameter and will interchange with the impala mounts no problem at all
  4. #4 Re: subframe mount interchange
    Oct 2014
    portland oregon
    i was told that gp and monte carlo ones interchange. but gp to impala i idk
  5. #5 Re: subframe mount interchange
    Feb 2013
    Missouri
    Sorry I didn't see this before. It makes sense that they all interchange, they are all W-bodies. The bolts\washers are the same so the mounts would be the same.
  6. #6 Re: subframe mount interchange
    I have one on my GTP from an Impala for weight reduction.
  7. #7 Re: subframe mount interchange
    Interesting. Pictures and part number by any chance.
    04 Comp G.
  8. #8 Re: subframe mount interchange
    Mine's a 97. 04 and up already have the aluminum subframe.
  9. #9 Re: subframe mount interchange
    Feb 2013
    Missouri
    We're talking about subframe bushings, not subframes.
  10. #10 Re: subframe mount interchange
    ^^ this
    04 Comp G.
  11. #11 Re: subframe mount interchange
    Arizona
    lower insulator front, w/firm suspension Left\Right
    http://www.trademotion.com/parts/200...&siteid=214858
  12. #12 Re: subframe mount interchange
    Feb 2013
    Missouri
    You press them in\out or what?
  13. #13 Re: subframe mount interchange
    Arizona
    Depends if you have the subframe in or out. I'll be posting a writeup shortly
  14. #14 Re: subframe mount interchange
    Feb 2013
    Missouri
    Any updates on this? How do they feel?
    How'd you change them with the frame in the car?
  15. #15 Re: subframe mount interchange
    Quote Originally Posted by Booba5185 View Post
    This
    04 Comp G.
  1. l36 to l67 pcm interchange questions
    By 98PONTIAC in forum PCM Tuning
    Last Post: 12-19-2012, 11:09 AM
  2. L67 coil mount/engine mount bracket (passenger side) on an L36
    By BlownBigBlock in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-28-2012, 10:08 AM
  3. pcm interchange ability
    By tedbuido in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2011, 07:31 PM
  4. Interchange
    By BwolfGT in forum Off Topic Discussion
    Last Post: 06-27-2010, 03:40 AM
  5. pcm interchange?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 05:39 PM
