Thread: fuel filter replacement
Results 1 to 20 of 25
  1. #1 fuel filter replacement
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    want to replace my fuel filter cause its old, and i have a bit of slow acceleration on the highway. say that it was only like $10 or $10 for the filter. video on YT was done on a GTP but is it still on the driver side? are there any "easy" ways of going around this. it seems like its easy enough but are there any tips on doing this. and like how much gas do i lose. oh and what kind should i get?
    '01 GT, OnStar antenna removed, GT emblem on grille, PONTIAC bumper inlay, engine cover and insulator removed, polished stock exhaust tips, 17" Bullitt rims
  2. #2 Re: fuel filter replacement
    id get what ever the parts store has. its better then the old one.
    when you take it off have a pan to catch the gas, only whats in both sides of the line will leak out for a while. a quart maybe.
    one you got the easy plastic clip side off. you want to hold the line nut still, and turn the filter off the line nut. the filters got a part for a wrench on it.
    if you turn the line nut it can twist the line.
  3. #3 Re: fuel filter replacement
    Sep 2014
    U.S.A
    so don't get one online, even its cheaper? the vid said to get one with the plastic clips? none of the ones i saw online had plastic clips, just a tube leading out of it. or are the clips attached to the line? couldn't i collect the gas and out it back in? lol I'm cheap
  4. #4 Re: fuel filter replacement
    well some gas will end up in your arm pits if your doing it right lol
    the plastic clip is on the line, you pinch it and it comes off the filter.
    you can buy a cheaper on on line. thats fine too if its cheaper,
  5. #5 Re: fuel filter replacement
    Never happened to me. You are clearly doing it wrong Doggy.
    If the plastic clip isn't on the new one, transfer your clip over.
  6. #6 Re: fuel filter replacement
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Or your eyes....
    2012 F150 STX
    - Gonna be a race truck
  7. #7 Re: fuel filter replacement
    maybe short folks got it easier, it runs down my hand to my fore arm, elbow, and next stop is the arm pit lol this working off your back of course, like most of us do.
  8. #8 Re: fuel filter replacement
    Apr 2012
    Dayton, OH
    Im not exactly short but im not exactly scotty size either and i didn't have that issue lol.
    2012 F150 STX
  9. #9 Re: fuel filter replacement
    Sep 2014
    U.S.A
    while were on the subject of fuel and stuff my fuel pressure regulator has like green lime scale or something on it and its not sealed. you can see a gap between the top and bottom. is it supposed to look this way?
    i just looked online and they're pretty expensive. could this be a JY part?
  10. #10 Re: fuel filter replacement
    GTP Level Member
    springfield IL
    I went with the wix filter. I've changed it every two years since 2010
  11. #11 Re: fuel filter replacement
    Maybe ... I'm doing something smarter than Scotty
    I don't relieve pressure or anything.. Crack it.. let it leak (without being directly under it or staring at it) and then wipe up the gas, spin the filter off.. spin the new one on, reconnect plastic line.. turn key on and check for leaks.
    Done
  12. #12 Re: fuel filter replacement
    thats how i roll too. over the years working on 4x4 trucks, lets just say its a more direct route down your arms.
    my 03 GMC i had to change the filter every year. after 12,000 miles it was clogged up, it also had a line nut on both sides.
  13. #13 Re: fuel filter replacement
    NJ gas..
    Regal has 258K on it..pretty positive it's the original filter
  14. #14 Re: fuel filter replacement
    owners manual says every 30,000 moles. but if you floored it off the line and it bogged before the shift it would then stall. fire back up ok. so after it did this a few times. i changed the filter. didnt happen again for like 10 to 13,000 miles. change the filter, all gone again. you could also not blow through the filter at all. solidly clogged up. so i just started changing it every 10,000 miles.
    remember, i was doing 3,000 miles a month at the time, and getting gas from all over the place. gassed up a lot on long island. so maybe bad NY gas? dont know really. never had another car or truck do this before. this one needed a filter every 3 to 4 months.
  15. #15 Re: fuel filter replacement
    Dude.. you know I was doing 1,000 miles a week for the longest time. Getting gas wherever as well. NJ/NY gas sucks.
  16. #16 Re: fuel filter replacement
    Mar 2015
    Erie,PA
    I dropped and flushed my tank when I changed out the pump. I couldn't believe how much crap was in the bottom of the tank. Looked like child's play sand in the bottom. I would say maybe a few ounces total of this "sand" type material. Took up a whole Saturday but I would try that route if you are going though fuel filters that much.
  17. #17 Re: fuel filter replacement
    Sep 2014
    U.S.A
    how do you relive the fuel pressure?
  18. #18 Re: fuel filter replacement
    Apr 2012
    Dayton, OH
    While car is running yoink the fuel pump fuse. Or do what bill said.
    2012 F150 STX
  19. #19 Re: fuel filter replacement
    Sep 2014
    U.S.A
    fuel pump fuse sounds like a better option lol
  20. #20 Re: fuel filter replacement
    or put a rag over the shrader valve on the fuel rail and use a screw driver to push the pin in to let the pressure out the line.
    either way gas will still drain from the lines a little bit. but you want the pressure relived.
  1. WTB: fuel line from injectors to fuel filter for 99GTP coupe
    By Swole in forum Wanted To Buy - Parts
    Last Post: 08-25-2014, 02:36 PM
  2. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  3. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
