Does any body knows what is the ohms for a blower motor resistor for a 2001 grand prix
Brian, you do realize that the connector plug for the blower motor resistor has 7-pins on it? Which set of pins are looking for a resistance reading from? I have a 2000 GP that I have a new blower motor resistor for that I have not installed as of yet. I could check it and let you know, but I need to know what set of pins you're referencing.
on the resistor pack what is the ohms on the three resistors
Don't think that you are looking at resistors. My multimeter was all over the place trying to read them out. Yes it is a Fluke 87 V. The top component which is reddish in color is marked as 192KR1 C0402. According to the Mouser Electronics site they are what appear to be ceramic capacitors but am trying to confirm that. The two lower ones (purplish in color) are much tougher to decipher due to their orientation on the blower motor resistor. Will get back to you on this when I've figured out what we are looking at.
Okay Brian here's what I've found. The electronic components in question are Thermal Cutoff Fuses or TCO's. There are three on the blower motor resistor assembly. The top one is a 192KR1 which is an SDF DF192S, 192C 10A Axial TCO, You can order this from Digi-Key part number 317-1139-ND; they are listed at $1.12 ea.
the two on the bottom are 152KR1 which is a DF152S, SDF DF152S Thermal Cutoff Fuse. You can also order these from Digi-Key, part number 317-1136-ND; they are listed at $1.12 ea also. Hope this helps you.
thanks a lot
