Thread: Air Conditioning info needed
Results 1 to 7 of 7
  1. #1 Air Conditioning info needed
    Greetings all,
    After 205,000 miles on my 02 GTP, the AC is getting a bit warm. Tried to add some Freon and noticed the low side Schrader valve is leaking.
    Been looking online and am having a bit of difficulty finding out which size I need for the low and high sides and a removal tool that will work without loosing pressure.
    Want to do the wife's 97 GT as well.
    Appreciate any info. Thanks in advance.
  2. #2 Re: Air Conditioning info needed
    St. Louis
    You won't be able to replace the valve w/o emptying the system. Might be called a "service valve" to help you find the right one.
  3. #3 Re: Air Conditioning info needed
    Better yet.. you usually can't remove that schrader. It's a crappy aluminum welded in aluminum over the years. I tried with my 02 this past summer. That's when my mechanic buddy said.. "you do realize the cap is the secondary seal".
    Once you get that cap on good.. it should hold. I say this because on mine..it's the high side that's holding.
  4. #4 Re: Air Conditioning info needed
    Thanks for the replies all.
    I was under the impression that the valves were similar to an "inner tube" screw in valve and the connection type was the schrader.
    I've seen the service valves online and some videos about doing it but I know there are different sizes for the low and high sides and am really having difficulty trying to find the info.
    Any more thoughts would be greatly appreciated. Thanks.
  5. #5 Re: Air Conditioning info needed
    I found the high side at Advance Auto. They actually stocked it. However I couldn't get the old one out.
  6. #6 Re: Air Conditioning info needed
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by airhead View Post
    Most of them are. I had a leak at the drivers side fitting (not sure if that is hi or lo) last time I got a recharge. Luckily my buddy does a lot of A/C work and had spares.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Air Conditioning info needed
    Apr 2014
    CT
    The low side I believe is a typical looking shraeder that can be replaced without losing pressure.
    http://www.ebay.com/itm/Mastercool-8..._Tools&vxp=mtr
  1. plog info needed
    By Dustoff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2014, 04:56 PM
  2. Info needed
    By Special K in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2013, 08:14 PM
  3. Info Needed
    By GaBear in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2011, 08:03 PM
  4. top swap info needed .
    By PALMCASTER GT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-29-2010, 01:40 PM
  5. tb spacer info needed
    By a98gtp4u in forum General Tech Discussion
    Last Post: 10-27-2009, 12:03 PM
