Thread: Brake Job DIY
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: Brake Job DIY
    Actuially you have that backwards Scott. Stock is 35mm and replacements are 34mm.
  2. #22 Re: Brake Job DIY
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    I just went took my tire off my 04 gp GT and got my sockets out so all u who think u know can be quite , btw those are after market just replaced c/v shafts
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  3. #23 Re: Brake Job DIY
    Jan 2013
    leavenworth ks
  4. #24 Re: Brake Job DIY
    you need bigger brakes lol
  5. #25 Re: Brake Job DIY
    SE Level Member Emptydarkone's Avatar
    Feb 2010
    Springfield, IL
    You're absolutely right! I should have known that a 33 MM will fit on my 34 MM and larger axle nut! The point is that axle nuts on these cars can have a range to them and you should probably measure it before buying the socket for them.
    Quote Originally Posted by Travisgt2 View Post
    Totally N/A - Mods: 18" Mustang GT wheels, leather scented air fresheners, medallion hanging from rearview mirror, custom tool box holder in trunk, and air horns in place of the factory honkers.
  6. #26 Re: Brake Job DIY
    Jan 2013
    leavenworth ks
    Quote Originally Posted by Jerseydoggs View Post
    Rofl thanks ill get right to it but its the dd so not high on to do lost now the trans am might need something like that probably bigger
  7. #27 Re: Brake Job DIY
    those are trans am, camaro, firebird brakes. (98-02) aka F body brakes.
    best damn up grade ever if you like to actually stop. the stock brakes are just so weak. i dont hot rod around town, nor am i even hard on my brakes. i just want brakes when i need em. these feel just like stock under normal driving, till you mash the pedal. and then you just stop, unlike them stock brakes.
  8. #28 Re: Brake Job DIY
    Jan 2013
    leavenworth ks
    Measure yes and I just did it. factory 33 aftermarket 34. Why would there be different sizes for the same vehicle???? I know its a larger c/v for the s/c 04+ because I was sold the wrong one and there a larger diameter and those probably have a different size but its a n/a 04 just as mine if u go to big a socket it can slip get stuck side ways or just strip it. I don't know a damn thing about 97-03 I don't know about 04+ s/c but an 04 n/a I know enough to be right and helpful just trying to help
  9. #29 Re: Brake Job DIY
    i just looked at my pics of my winter wheels, looks like i can slip the socket into the nut wheel on. ill see wtf im using.
    why is a good question, maybe to spread the load on the wheel bearing better with a larger nut?
  10. #30 Re: Brake Job DIY
    Apr 2013
    Chicago Land
    We finished the brake job but we didn't tackle the passenger side wheel hub. I plan on swapping that out in the spring since the temperature will be above 5 degrees then. We didn't have the right tools to swap out the hub anyway or we would have tried to do it.
    Edit:
    I was surprised at how easy it was to do. I will never pay a mechanic to do a brake job again. I still have doubts that the hub replacement will go as smoothly.
  11. #31 Re: Brake Job DIY
    Jan 2013
    leavenworth ks
    Pb blaster is ur best friend!
  12. #32 Re: Brake Job DIY
    ive never paid to have brakes done......ever.
