i went driving today but when i started my car my low coolant light came on. the last time it came on was when it was -35 degrees outside. last night probably didn't even hit 20 degrees. it was pretty warm for being winter. anyway there is no way it froze. so i went driving and after about 5-7 minutes, the light turned off. then a few minutes after that turned back on and then off right away. then back on and stayed on. i just checked the radiator to see if the coolant was actually low and this is what i found...
is the sludge on the sides normal? the cap didn't have much on it but it did have some. and how far up should the coolant be? at the very tippy top or just a bit down from it? i just don't want it to turn out to be a head gasket issue
