Thread: Low Coolant came on
Results 21 to 40 of 68
  1. #21 Re: Low Coolant came on
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    B.S.
    It won't eat aluminum if properly maintained...age and air make it acidic
  2. #22 Re: Low Coolant came on
    The Boss Iceman6669's Avatar
    Jun 2011
    Negative. cavitated motors will cause dex to fail.
    2011 F-150 Yote powered
  3. #23 Re: Low Coolant came on
    Enfield, CT
    Quote Originally Posted by Iceman6669 View Post
    Dexcool has also been shown to eat aluminum parts. Which is what the LIM is made out of.
    BS. you didn't maintain it properly. You're thinking of the green sh!t. Green stuff wears down aluminum faster which is why manufacturers no longer use it considering water pumps, radiators and newer engines and heads are aluminum.
    Just wanted to say this first. If you really believe that the green sh!t is better then great. Run that crap in your car because your car isn't my problem lol
  4. #24 Re: Low Coolant came on
    Jun 2011
    Read the post right above yours.
  5. #25 Re: Low Coolant came on
    Enfield, CT
    I did. BS. just maintain it properly and you're good
  6. #26 Re: Low Coolant came on
    Jun 2011
    You can write the letters BS all you want. You are still wrong.
  7. #27 Re: Low Coolant came on
    Dexcool is corrosive when mixing with the moisture...which is a lack of caring for the system.
    Case in point, my old man's 15 year old Camaro...it's got dexcool. Everything is fine and sludge free, no engine failure.
    My mom has a 2003 LeSabre with dexcool as well...only thing that was touched was the intake gaskets when her manifold warped like many of them did (N/A) car. That motor is spotless.
    The only reason I don't run dexcool is because of these easy reasons:
    1) Price
    2) Mixability
    3) I'm lazy and the green/yellow stuff works
    The end
  8. #28 Re: Low Coolant came on
    Enfield, CT
    Quote Originally Posted by blueguy View Post
    1) Price
    2) Mixability
    The end
    huh? what does the red mean?
  9. #29 Re: Low Coolant came on
    Jun 2011
    I talked with Matt about it a while back and it is still corrosive to aluminum parts even when properly maintained when in a cavitated motor. Which was one of the biggest reason Ford ditched the 4.6L and redesigned the 5.0
  10. #30 Re: Low Coolant came on
  11. #31 Re: Low Coolant came on
    Enfield, CT
    he's wrong dude. if they ditched the 4.6, why not ditch the 5.4? same engine different stroke man. the redesigned the 5.0 because it's their most prized and worthy motor.
    Nice post scotty lol
  12. #32 Re: Low Coolant came on
    i swing from both sides of the fence lol ive seen this before, ill see it again.
  13. #33 Re: Low Coolant came on
    Enfield, CT
    Quote Originally Posted by Jerseydoggs View Post
    so you're Bi about this?
  14. #34 Re: Low Coolant came on
    Jun 2011
    The "DexCool" designation means the coolant passes General Motors performance testing. Although DexCool is not a specific formula, all three brands that have the label (Texaco Havoline, Prestone Extended Life and Zerex Extended Life) are somewhat similar. In particular, they're OAT coolants, but the similarities go beyond that basic description.
    All DexCool-approved coolants to date use two organic acid rust/corrosion inhibitors, one called sebacate, the other called 2-EHA (which stands for 2-ethylhexanoic acid). These organic acids are very stable and last a long time, although they take thousands of miles to become fully effective in protecting coolant passages.
    Hybrid OAT (HOAT) coolants, such as "Zerex G-05ยจ." Use organic acids, but not 2-EHA (2-ethylhexanoic acid) (different organic acids are used). Hybrid OAT coolants add some silicate to provide quick-acting protection for aluminum surfaces.
    This was after some quick Google work.
  15. #35 Re: Low Coolant came on
    Enfield, CT
    not everything on google is accurate.
    americans use acid
    asians use phosphates
    germans use silicias IIRC
  16. #36 Re: Low Coolant came on
    Enfield, CT
    Josh, just run that green ****
  17. #37 Re: Low Coolant came on
    Quote Originally Posted by HighOctaneRacing View Post
    lol...about that.
  18. #38 Re: Low Coolant came on
    yup. i dont give one flying fvck what coolant anyone runs lol
    in the end it dont matter. flush it as needed, and keep it topped of and nothing should go wrong.
  19. #39 Re: Low Coolant came on
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    When running, I prefer the orange stuff. That lime flavored green is nasty.
    Low Coolant came on Attached Images
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  20. #40 Re: Low Coolant came on
    X2 on the orange dank..... lol
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
