Thread: Low Coolant came on
Results 41 to 60 of 68
  1. #41 Re: Low Coolant came on
    Mar 2014
    Tucson
    Isn't it also recommend that you use distilled water when mixing, regardless of the coolant type? Does anybody actually do that? And how much does that affect the condition and longevity of the coolant?
  2. #42 Re: Low Coolant came on
    ive never used distilled water once in my life. (hose water for life) never had a issue. and i never use pre mixed either.
  3. #43 Re: Low Coolant came on
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    As I said before, I don't really care what the reason it sludges up is, it shouldn't do that, period. Dex sludges, green **** doesn't, end of story.
    If someone made an engine oil that turned into sand without "proper maintenance", you think that would be cool? Blame the owner for not changing it at 3k miles on the dot for it? Seriously?
    My Suburban and Blazer also both sludged up with dexcrap, no issues with intake gaskets, doubt the systems had air in them for 50k miles. I don't care what coolant people run either, but they should at least get as much info as possible to make an informed decision.
    Show me where green coolant ever sludged up.
  4. #44 Re: Low Coolant came on
    Enfield, CT
    Quote Originally Posted by 99GT2dr View Post
    LMAO! That black sludge you see is the plastic LIM gaskets failing dude. Dexcool doesn't turn black lol. Plastic gaskets will fail regardless of what coolant you use. Like I said before green **** isn't good for aluminum hence why manufacturers don't use it anymore. Like I said before, it's your car and whatever problems you get are your problems not mine so IDGAF what you do, just trying to help you lol
  5. #45 Re: Low Coolant came on
    Cibolo, TX
    Umm, point out to me where I ever mentioned anything about "black sludge"? It's orange sludge, and I had to dig it out of the coolant ports on both heads on every 3800 car I've pulled a LIM off of. Lots of chunky orange goodness from the rad ofc, never pulled the end tanks off to see what it looked like inside there, though. The Dex isn't any better for aluminum, so I don't know where you're getting that info from, my regals lim was pitted to hell around the coolant ports, would've taken pics but it's already pretty well documented.
    Idgaf what anyone does either, like I said, they can read the info, Google search images of dexcool, and make their own decision. Manufacturers also don't care what's best for the car, so don't let that be your guide, they're out to make money. If it outlasts the warranty period, they could give a **** less what happens afterward.
  6. #46 Re: Low Coolant came on
    Enfield, CT
    If your LIM and other aluminim parts are pitted, you did not maintain the system properly.
    I'll quote another smart guy
    Quote Originally Posted by 231FUN View Post
    B.S.
    It won't eat aluminum if properly maintained...age and air make it acidic
  7. #47 Re: Low Coolant came on
    Cibolo, TX
    Age? It's allegedly good for 100k miles/6 years iirc. Keep on rocking it if you like it bro, nobody's stopping you. Don't try and convince me to make yourself feel better, though, lol. Had too many engines apart that tell a different story, apparently every one of them with air in the system their whole life, lmao.
  8. #48 Re: Low Coolant came on
    Enfield, CT
    100k 5 years so going 6 years is an issue and you not knowing that is one of your problems. Also, I don't have to convince you. I'd rather you run the green stuff because it'll boost our economy. I'm just listing valid reasons on here so people who want to learn don't end up like you. Lots of people think they bleed the system correctly but don't. I'm sure you've had many engines apart and that's a sign that you don't know what you are doing and what you're talking about. Again, please put the green stuff in and use the plastic gaskets BRO! LOL!!!
  9. #49 Re: Low Coolant came on
    Cibolo, TX
    I hope your education wasn't paid for, if so, a refund is in order.
  10. #50 Re: Low Coolant came on
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by HighOctaneRacing View Post
    So what you are saying is, you should never buy a used car with Dexcool in it since you can't be sure that it has been "properly" maintained and the internal aluminum parts could be pitted...
    2011 F-150 Yote powered
  11. #51 Re: Low Coolant came on
    GTP Level Member
    Oct 2014
    That escalated quickly
  12. #52 Re: Low Coolant came on
    Enfield, CT
    Lol no. Education comes from GM dealerships and engine rebuilding shops. You're the one who needs the refund haha.
  13. #53 Re: Low Coolant came on
    Enfield, CT
    Quote Originally Posted by Iceman6669 View Post
    Never said you shouldn't buy a vehicle with dexcool. You know you can have some pitting and the parts are gonna be fine. It would take a very very long time for unmaintained dexcool to completely destroy aluminum parts. You would also see if there was severe damage to the aluminum parts by looking at the coolant.
  14. #54 Re: Low Coolant came on
    Jun 2011
    Well pits in the aluminum could potentially cause cavities which would expose it to air... So my point remains, with the risk running Dexcool, why would you risk it?
  15. #55 Re: Low Coolant came on
    Enfield, CT
    "COULD POTENTIALLY" It's been said over and over and over again, MAINTAIN IT PROPERLY and you won't have issues. Is that so hard? Like it's been said over and over and over again, Green coolant isn't good for aluminum hence why all manufacturers dont run it anymore and use their own version of 5 year coolant.
    Now, again, use what makes you sleep better. If you don't mind, I have to deal with a much more serious issue right now thanks to a dumb ass lady burning our apt building down
  16. #56 Re: Low Coolant came on
    I break stuff selliott's Avatar
    Kansas City
    Popcorn anyone? Lol
  17. #57 Re: Low Coolant came on
    Cibolo, TX
    Well I guess you got me bro, even in 3rd grade I never could figure out a good comeback to the old, "Nuh uh, you!" defense. You are the exact reason people not under warranty avoid dealerships like the plague. Not going to bother refuting any of your points anymore, as you just ignore what's inconvenient and completely fabricate other stuff to support your argument.
    Best of luck with the fire, hope it wasn't too bad, especially being in an apartment.
  18. #58 Re: Low Coolant came on
    Enfield, CT
    Agree to disagree. It was bad. We had to jump out of friggin 2nd floor and 3 floor windows and a tenant died. We'll get it figured out. Thank You
  19. #59 Re: Low Coolant came on
    Kansas City
    Holy crap that sucks, sorry man
  20. #60 Re: Low Coolant came on
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I'm pretty sure I said it needs to be changed out as often as the green stuff many posts ago.
    It don't last five years...which is the biggest problem when claims are made that it does.
    My properly maintained and regularly flushed l67 has no such pitting/cavities in the aluminum after having dexcool in it for 13+ years.
    But run whatever you want...
  1. Coolant reservoir has brown junk in it and low coolant light flashing. what is it?
    By JessicaRebel in forum General Grand Prix Discussion
    Last Post: 09-15-2014, 08:37 AM
  2. Flashing Low Coolant Light, Coolant Full, No leaks
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2012, 08:25 PM
  3. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
