So how do I change the super charger oil? Where can I buy it? How many bottles will I need ? How do I know the correct level to fill it to? I need step by step advice. I never done it before and don't want to screw anything up. Thank You
There is a video on you tube.
It's simple
Loosen the hex socket on the snout where the oil goes. Use either the top of a spray bottle or syringe to extract the old oil and spray it info a cup/bowl or w/e. Fill it with new sc oil until it full takes little under 2 bottles.. Put bolt back on and bam.. All done..
Oh and you damn sure better wear two pair of gloves because if you get it on your hands.. Good luck washing it off
