View Poll Results: What is causing the leak?
Voters
16. You may not vote on this poll
  • A: Oil filter
    1 6.25%
  • B: Pressure sensor
    5 31.25%
  • C: Bill doesn't care
    4 25.00%
  • D: All of the above
    6 37.50%
Thread: Where's the leak
Results 1 to 20 of 23
  1. #1 Where's the leak
    Drive to work today.. 35ish miles at highway speeds, then backroad speeds. Look at phone upon arrival and see a message from my other half "Good morning sweetheart, I think your car is leaking oil". Get out and look.. sure is, and it's leaking pretty good over at the passenger side. Right around the oil filter area.
    Question is.. is it from the crushed oil filter that I left on there when I changed the flex plate? Did the oil pressure sensor blow it's load (Scotty's favorite), Did something kick up and magically make it leak, or ... D all of the above?
  2. #2 Re: Where's the leak
    Aug 2013
    McDonald PA
    I'm saying sensor. But the oil filter will be a ***** to get off cause it's crushed and could also be oozing but I guess Scottys favorite
  3. #3 Re: Where's the leak
    I have run quite far on the filter.. so I'm not sure it's the filter.. although it did get moooooshed
  4. #4 Re: Where's the leak
    ill vote D lol
  5. #5 Re: Where's the leak
    Mar 2012
    NC
    I voted C. Bill doesn't care...except that it leaves puddles in the fancy-pants-house's driveway. LOL
    EDIT: Garage...because fancy-pants-house.
  6. #6 Re: Where's the leak
  7. #7 Re: Where's the leak
    Jason..I don't park in the driveway. there's a garage
  8. #8 Re: Where's the leak
    Mar 2012
    NC
    Fixed for your enjoyment.
  9. #9 Re: Where's the leak
    Nice..
  10. #10 Re: Where's the leak
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Bill cares enough to make a post, so I'd say C and D are out. Considering the oil filter is smushed, I'm going to say A.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  11. #11 Re: Where's the leak
    Actually.. posting is what I do. Especially when I don't care.
  12. #12 Re: Where's the leak
    true story. as soon as i saw who posted it i knew its a gag thread.
    heres how i see this going down. bill checks his oil, see its full enough to drive or not, then im sure while at work if its not wet outside like it is here, can look for the leak, figure it out, then hit the parts store for a new oil filter or hardware store for a plug to fix that dumb worthless oil pressure sensor should it be leaking.
  13. #13 Re: Where's the leak
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    C for the win.
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  14. #14 Re: Where's the leak
    Scott... I'm out in the middle of the woods at work. Closest parts store looks to be like 10-15 miles. I'll buzz up the road to a gas station and check it, grab a couple of quarts and drive... If it blows, I'll part it and buy something else.
  15. #15 Re: Where's the leak
    dibs on the sound system......
  16. #16 Re: Where's the leak
    LOL.. you want the sub box..don't ya
  17. #17 Re: Where's the leak
    id take the whole thing, dash to back bumper lol if i could only afford it now.....
  18. #18 Re: Where's the leak
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I'm going to guess pressure sender. Oil filter would have leaked right away if it was the problem. Never a good feeling wondering if you had oil pressure during your drive.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  19. #19 Re: Where's the leak
    Mar 2014
    Tucson
    IIRC, that isn't a huge concern for him. Isn't he the guy who bled his power steering system with ZERO oil in the crankcase?
  20. #20 Re: Where's the leak
    LOL.. Yeah that was me. Only ran it for a minute and didn't put it in gear etc. Yes though.. it's not a huge problem if something happens.
    Let's call my solution the ScottyDogger way to fix oil leaks. I pulled the connector and the culprit was the oil pressure sensor. I checked the toolbox drawer for a sensor (there's a misc sensor/pigtail drawer) and found 8 of them. Since this is not one of the body styles with a gauge and I had plugs on hand, I tossed one in. Scott says it right when he tells people that there's no value to that sensor. The light comes on when the pressure hits 5psi and the motor is already toasted. Why bother with a sensor? Plug it is!
    Did an oil change at the same time.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
