Thread: Screeching while turning right! Help!!
Results 1 to 11 of 11
  1. #1 Screeching while turning right! Help!!
    GT Level Member kyliek23's Avatar
    Feb 2013
    Ok so i know i posted something about this a long time ago but its getting worse and i cant figure out what it is! (my car is a 2005 GP base) It happens whenever i turn right, but the kick is, only when i do wider turns not sharp turns. it makes a screeching and grinding noise, just like when a break pad is getting low and the indicators are touching the rotor. i do need to replace my front right sway bar link but not sure if that has to do with my problem. Anyone have the same issue?? i replace my brake pads about 3 months ago tops. so it shouldnt be the pads. please! help me!! its really annoying!
    2005 Pontiac Grand Prix Base
  2. #2 Re: Screeching while turning right! Help!!
    Enfield, CT
    did you replace the brake hardware? are you sure it's not the power steering pump?
  3. #3 Re: Screeching while turning right! Help!!
    Feb 2013
    i know its not the power steering pump because its coming from the front right tire area. and i bought the duralast gold ceramic brake pads which come with the hardware. so each side were replaced. the noise is coming from the front right only. unless they were put in wrong or loose?
  4. #4 Re: Screeching while turning right! Help!!
    Enfield, CT
    I wouldn't know if you put the hardware on wrong since I have no pics to verify but you may have defective clips and/or pads but the best thing to do first is take off the wheel and look at the brakes. Caliper could be shot or just need to grease the slider pins but we are getting too far ahead. take the wheel off and look and go from there
  5. #5 Re: Screeching while turning right! Help!!
    Feb 2013
    Alright I'll let you know shortly
  6. #6 Re: Screeching while turning right! Help!!
    Feb 2013
    Well wheel had a little play in it when you wiggle it from the sides. So wheel bearing is taking a crap. But to rule out the plate behind the rotor, we bent it away from rotor to see if it would make a difference. If it does its was that, if not its most likely my wheel bearing. Yay. :/
  7. #7 Re: Screeching while turning right! Help!!
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    also look for signs of things rubbing against eachother. never know could be something dumb like that.
  8. #8 Re: Screeching while turning right! Help!!
    Feb 2013
    Ok. I looked at the rotor and it didn't look or feel like anything was scrapping against it
  9. #9 Re: Screeching while turning right! Help!!
    Enfield, CT
    Well at least you are one step closer. Also check the bracket that protects the balljoint
  10. #10 Re: Screeching while turning right! Help!!
    Feb 2013
    Ok. I'm hoping I fixed it with bending the heat "shield" behind the rotor. Do they make replacements for those?
  11. #11 Re: Screeching while turning right! Help!!
    Enfield, CT
    Quote Originally Posted by kyliek23 View Post
    yes but it takes some work to replace. don't bother replacing it unless it's really screwed up
  1. Screeching from wheel
    By Sulvestr in forum General Tech Discussion
    Last Post: 05-30-2014, 12:03 AM
  2. Belt Screeching
    By ILoveAudi in forum General Grand Prix Discussion
    Last Post: 09-24-2013, 01:37 PM
  3. Screeching Sound, But Not From Belt
    By LeoD in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-28-2013, 11:48 AM
  4. Screeching sound, but not from belt
    By LeoD in forum Introductions/Noob Questions
    Last Post: 02-26-2013, 01:51 AM
  5. Brakes screeching
    By Steven Monteith in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2012, 12:56 AM
