Thread: Lightning Strike
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 Lightning Strike
    Sep 2014
    South Carolina
    This is my first post so if I do anything wrong, please let me know.
    On 09/02/14 my car was struck by lightning and I have been fighting with the dealership and insurance to get the car fixed.
    So far the dealership has replaced the alternator and battery. The car runs and drives.
    My current issues are:
    -Shifts a little firmer than normal
    -Cannot read PCM through OBD port
    -DIC is flashing 0
    -DIC doesn't show boost or performance shift mode
    -TCS Off Light is on
    A different DIC fixed the TCS Off light but it still flashes 0 and the TCS button doesn't toggle TCS.
    A different computer can be read through the OBD port but doesn't fix the flashing DIC.
    Any ideas what could be wrong guys? Thanks
    Everything on the car worked before the lightning strike, all fuses looked good.
  2. #2 Re: Lightning Strike
    Mar 2012
    NC
    Typically when lightning hits a vehicle, you can guess that any control module in the car is now dead. PCM...probably toast. ABS module...probably toast.
  3. #3 Re: Lightning Strike
    Sep 2014
    South Carolina
    Well the car wasn't hit directly and the lights on the dash for the ABS module aren't on. I agree that the pcm is trashed but the dealership doesn't. But even when I put a different pcm in that I could read the DIC still flashes. I tried a different DIC with a working PCM and it still flashes as well.
  4. #4 Re: Lightning Strike
    Aug 2011
    'Merica
    Have you checked all fuses under the hood as well as in the car?
  5. #5 Re: Lightning Strike
    Sep 2014
    South Carolina
    All fuses looked good to me, under the hood and in the car.
  6. #6 Re: Lightning Strike
    last guy who i knew whos car was hit by lighting...well lets just say its in a junk yard. almost every wire in the car smoked up and burnt.
    so short of replacing every wire and sensor, module, clusters and so on. it may never be right again.
    i would do my best to get them to total the car, then go buy a new one. if need be call a lawyer. cause it may never be right again.
  7. #7 Re: Lightning Strike
    Sep 2014
    South Carolina
    Haha not exactly what I wanted to hear but it is kinda what I expected. I don't think it fired any wires as it wasn't a direct strike, my car was within about 10 feet of the strike and doesn't show any markings.
  8. #8 Re: Lightning Strike
    all i know is lighting kills cars and people lol
    id keep asking the ins co if they want to drive a car thats not right, its not how it was before the lighting strike, so either total it, or fix it, or call a lawyer to help make them make a decision. and make them pay your lawyer fees too. cause they are not doing right by you at all.
    ins is to make you or your car whole again, this has not happened.
  9. #9 Re: Lightning Strike
    Feb 2014
    Grand Forks, North Dakota
    You should definitely make the insurance company pay to fix it or total it out. What happens if you get in an accident and the airbags do not deploy, or none of the other safety equipment works? You don't want to find out the hard way.
    40th Anniversary GTP. No name brand HAI. Partially clogged cat.
  10. #10 Re: Lightning Strike
    Howell, NJ
    How do you know it got hit by lightning? That would be hard to prove also.
  11. #11 Re: Lightning Strike
    Banned
    Jan 2013
    Colorado
    Quote Originally Posted by 99coupegtp View Post
    they look good or did you physically check them all?
  12. #12 Re: Lightning Strike
    Sep 2014
    South Carolina
    Quote Originally Posted by brugg125er View Post
    Yeah that would not be fun at all. They don't want to put a lot of money into my old car is basically what insurance said. It runs and drives so they're pretty happy with just that. I did get them to approve the stealership more time to diagnose my other issues.
  13. #13 Re: Lightning Strike
    Sep 2014
    South Carolina
    Quote Originally Posted by Jomamma View Post
    I parked the car at my mom's house in perfectly running condition. While I was inside the house near the front door lightning struck a tree outside the front door which also hit the house because some smoke came in the front door from the top. My car was next to the tree that was hit and would not start afterwards. Killed the battery, alternator(which caught fire at the dealership), DIC, ICM, and possibly the PCM.
  14. #14 Re: Lightning Strike
    Sep 2014
    South Carolina
    Quote Originally Posted by camopaint0707 View Post
    I pulled almost every one of them and inspected them visually. Unfortunately I did not have my multimeter with me to test them.
  15. #15 Re: Lightning Strike
    Sep 2014
    South Carolina
    Finally got the fools at the dealership to agree the PCM was bad. I told them two weeks ago it was. I was also assured earlier this week that they checked it.
  16. #16 Re: Lightning Strike
    Sep 2014
    South Carolina
    Alright, so I have my car back and it runs and drives with minor issues. I doubt anyone will see this as this post is old but I have a few other questions.
    I have replaced my PCM and had it reprogrammed with my old tune. It can now be read through the OBD port and the car shifts normally as well.
    Issues:
    The DIC still flashes 0's.
    The CJ2 climate control unit is throwing a UART Serial Data Line Fault code (07).
    The PCM is throwing three fault codes. P0172, P1133, P1571. (One of these is the ABS module.)
    It seems as though neither the DIC nor the CJ2 module can communicate with the PCM, assuming both of them actually do. Is there a module between them and the PCM? I have tried another DIC and still had the same issue. I have also tried 2 other CJ2 modules which also had the same issue.
    I know most people have said to just scrap the car but I have put too much time into this car and love it too much. It has never given me any issues that I haven't caused with upgrades lol. It's in too great of shape to just trash as well. That being said, please don't comment saying the car should be scrapped, please give suggestions on what to try to fix the issue.
  17. #17 Re: Lightning Strike
    Mar 2012
    NC
    The EBCM is dead...AKA ABS module. When you access the ABS module for data, the DIC flashes...I know this for a fact. If the ABS module goes down, it's gonna make the DIC blink.
  18. #18 Re: Lightning Strike
    http://www.obd-codes.com/p0172 o2 or vac leak
    http://engine-codes.com/p1133_pontiac.html o2 h02
    http://engine-codes.com/p1571_gmc.html ecbm maybe fried.
    i still want to know why insurance is not fixing this. its there job to make sure your made whole again.
  19. #19 Re: Lightning Strike
    Sep 2014
    South Carolina
    Really? I drove the car without one for a while and the DIC worked. I figured my EBCM was trashed since traction control doesnt work. ABS still works though, I've confirmed that. Thanks a ton, I'll try a replacement when I get the chance.
  20. #20 Re: Lightning Strike
    Sep 2014
    South Carolina
    They basically said they don't want to dump money into a car this old even though it looks great and drives perfectly. They wanted to total it but we weren't accepting that. Thanks for your help
  1. The new 6 Strike Copyright Alert system and how it works
    Last Post: 03-26-2013, 03:48 PM
  2. SVT LIghtning Vs 01GT
    By 01gpgt01 in forum Track Sessions and Kills
    Last Post: 01-08-2012, 06:17 PM
  3. Stealership strike again!
    By tayl5645 in forum The Rant Forum
    Last Post: 01-31-2011, 02:25 PM
  4. Lightning Strike At A Gas Pump
    Last Post: 10-07-2008, 03:13 PM
  5. Lightning pic
    By Toofastgs in forum Off Topic Discussion
    Last Post: 06-06-2008, 12:33 PM
