Thread: New battery," Anti theft system disable starting" shows up
Results 1 to 2 of 2
  1. #1 New battery," Anti theft system disable starting" shows up
    Jul 2012
    Lawrence, KS
    Hello all. Subject says it all. Got a new battery 2 days ago. Got it in, the car started right up. Sat for 2 days, get in to go somewhere today and it says "Starting Disabled due to Anti Theft System". I search online, some say leave the key in turned to "on" posistion for ten minutes. Didn't work. Called one of the local dealer ships, what they suggested didn't work. So how can i get my car started again without having to take it to dealership? 05 Grand Prix base model. Another subject, cars display also says Battery Drain Failure or something like that. That tells me right there that i need a new alternator, correct? Thats the reason for the new battery, old one was dead and wouldn't hold a charge, plus it was bulging on the sides. Any help would be welcome.
    Solved.
    The new battery was bad. Since it was under warranty, i went and got a new one. Plus, took the alternator off and had it tested, it was good. Put everything back together, car started right up. So, all is good.... for now.
  2. #2 Re: New battery," Anti theft system disable starting" shows up
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    The bulging in the battery is caused by over charging. The heat from the over charge turned the acid which is liquid to a gas which has expanded.
  1. anti theft system needs service
    By mamakeel in forum Introductions/Noob Questions
    Last Post: 10-29-2013, 04:05 PM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. Service Anti Theft System
    By silentkreeper95 in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2012, 08:05 PM
  4. Replacing Anti-theft system
    By mvp2765 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2010, 09:03 PM
  5. 1997 grand prix anti-theft system components
    By Konstantin in forum Audio, Security & Visual Electronics
    Last Post: 10-10-2010, 03:36 PM
