Thread: Will removing the catalytic converter make the 08 models burn more gas??
Results 1 to 20 of 20
  1. #1 Will removing the catalytic converter make the 08 models burn more gas??
    Jackson, Mississippi
    Hello everyone. I am considering removing my cat and going with a straight pipe instead of buying a new one. But I have heard from a few people that the 08 models must have a cat or it will burn gas like crazy. Does anyone know for sure if this is true for that particular year??
  2. #2 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Nothing good comes with removing the cat. Car is going to fail emissions, it will set codes on the dash, probably will affect mileage and it's going to smell like ass when it's idling with your windows open.
    I wouldn't bother.... Put a high-flow cat on if anything instead of going without. Those can be had for <$100 instead of $300+ for an OEM comparable at a muffler shop.
    I am sure someone will come in say "but you'll have more POWAAAAA". Unless your car is insanely balls-to-the-wall modified, I see it being very negligible.
  3. #3 Will removing the catalytic converter make the 08 models burn more gas??
    Aug 2013
    McDonald PA
    Just saying. High flow cat will probably set the ses also
    Ask me how I know
  4. #4 Re: Will removing the catalytic converter make the 08 models burn more gas??
    It will likely use more gas if it keeps running a cat test because it's no longer there. And the check engine light will always be one and being a 2008 is got a year only computer with can bus.
    I would find an aftermarket cat and weld it in place. I would not get a high flow unit as it does what it says, flows too well for what the car wants to see.
  5. #5 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Quote Originally Posted by mcdavidhome View Post
    Thanks for the info
  6. #6 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Thanks for the input..
  7. #7 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Quote Originally Posted by Damnir View Post
    Thanks for the info...
  8. #8 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Enfield, CT
    Go cat-less and get a tune that way the codes won't show up and you won't burn thru gas
  9. #9 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Get a high flow cat and either a tune or use the spark plug fouler trick..
    04 Comp G.
  10. #10 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Quote Originally Posted by HighOctaneRacing View Post
    Ok thanks.
  11. #11 Re: Will removing the catalytic converter make the 08 models burn more gas??
    ok. How can i get instructions on doing the fouler trick?
  12. #12 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Aug 2011
    'Merica
    Youtube it.
    https://www.youtube.com/watch?v=KnYUHwTxKkE
    This will get you started.
  13. #13 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Aug 2013
    McDonald PA
    Ok thanks.
    You can't tune an 08 period to end
  14. #14 Re: Will removing the catalytic converter make the 08 models burn more gas??
    GT Level Member blownGP's Avatar
    Sep 2013
    Iowa
    Why? Also I have no cat and no CEL
    2000 2500 Chevy with 6 inch lift build thread- http://www.gmt400.com/forum/showthre...d-Crew-Cab-454 2006 Grand Prix supercharged build thread- http://www.grandprixforums.net/blown...ead-82585.html
  15. #15 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Because you can't. I already said why, year only computer with can bus.
  16. #16 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Aug 2013
    McDonald PA
    This it's been reiterated
  17. #17 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Quote Originally Posted by Below Average Joe View Post
    Youtube it.
    Thanks!
  18. #18 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Please forgive my ignorance, but can you explain what "year only computer with can bus" mean?
  19. #19 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Aug 2013
    McDonald PA
    It's a locked down pcm
  20. #20 Re: Will removing the catalytic converter make the 08 models burn more gas??
    Thanks!
  1. WTB: Catalytic Converter
    By 91RS in forum Wanted To Buy - Parts
    Last Post: 06-16-2014, 12:20 PM
  2. Catalytic Converter HELP!!!!!!
    By KickerGrandPrix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2012, 06:48 AM
  3. Catalytic Converter?
    By Lawenforcer in forum General Tech Discussion
    Last Post: 02-21-2012, 02:53 PM
  4. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
