Thread: Should I Buy a GTP or GXP
Results 1 to 20 of 30
  1. #1 Should I Buy a GTP or GXP
    Sep 2014
    NC
    Hey guy's I'm a first time poster but I've been on the sight numerous times. So I'm ready to buy a new(ish) car and I've decided I want an 04-08 grand prix but, I can't decide to go gxp or gtp. Either way the car has to be low mileage (less than 60K) and around $10k.
    -The GXP: I was dead set on a gxp but after reading about transmission issues I've kind of been scared to commit on anything high mileage. I figure if I get a low mileage (less then 50K) gxp and slap a large trans cooler on it and change the fluid/filter every 20-30k miles I should be ok but I'm not 100%.
    -The GTP: I haven't heard nearly as many reliability problems about gtp gearboxes even though they're near identical.
    Either way I'm gonna daily drive the thing and put about 7,000 miles a year on it.
    The GTP I was looking at
    Car 1
    The GXP I was looking at
    Car 2
    Thanks for your input.
  2. #2 Re: Should I Buy a GTP or GXP
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    GTP's are exponentially easier to modify because they came supercharged. Also they're usually cheaper to begin with.
    The transmission is the same in both cars. They both have the same issues... they're just magnified in the GXP because in stock form they make more power/torque through the same transmission.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  3. #3 Re: Should I Buy a GTP or GXP
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I'd say, go with the GTP every time, unless you MUST have a V8.
    With the prices I have seen on GXP's, you could probably build a 400+hp Turbo GTP for less money. The insurance for the GTP will be cheaper. The GTP will be better on gas. I would also imagine an L67 will be cheaper to maintain and last longer, all else being equal.
    As for the transmission... yes, it has to deal with more torque, but also, I've heard many times that the aluminum block LS4 transfers heat to the transmission more readily than the iron 3800.
    I'm not saying the GXP is a bad car at all, but for 11K ... you can almost get a real muscle car with RWD. The GXP just doesn't seem like a good value.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  4. #4 Re: Should I Buy a GTP or GXP
    GTP Level Member buickman104's Avatar
    NYC
    Are you going to mod?
    What is your driving style?
    How mechanically inclined are you to do your own work on your car? Or do you take it to a mechanic shop to get the car serviced?
    What kind of MPGs are you expecting to get?
    Do you mind the cost of Premium over regular?
    My point is with 10k you can buy many cars out there! I have even seen some First Gen cts-v cars with the 395HP LS6 engine for 10k. So don't limit your options as much. It is more important to know what you expect out of the car and we can let you know the short coming from personal experience of owning these cars and working on them.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: Should I Buy a GTP or GXP
    St. Louis
    G8 gt, gto...
  6. #6 Re: Should I Buy a GTP or GXP
    comp g all the way
  7. #7 Re: Should I Buy a GTP or GXP
    Sep 2014
    NC
    It is true I can get more car for the money but I don't think I'd like to pay the insurance on something with 400 horsepower (I'm 23). Also I'd ideally like to find a car with less then 60k and I don't think anything with and ls6 or ls2 is gonna be around my price with that mileage. Right know I daily drive a 1962 c10 shortbed steps side with a 327 m21 4 speed and 3.90 gears, so in all reality any variant of the grand prix would get at least double the mpg I'm pulling right know. I'm fairly mechanically inclined (a couple motors swaps, built a couple small block chevy's, rebuilt a manual tranny once, basic stuff), never have and never plan to take any of my cars to a mechanic. Premium, midgrade or regular gas is fine. If I could pull ~20mpg city and ~30mpg highway that would be cool. Realistically I know these cars are nose heavy front drivers and are gonna handle as such but I don't need a race car. I'm just looking for reasonably peppy ride, with a relatively roomy interior, pulls decent mileage and not too high insurance. If I got the gxp I would do and ls6 intake manifold with matching injectors, 3" down pipe with no cat, crane quick ratio rockers, and a tune all going through stock mufflers. The gtp would get some rockers, colder plugs, a 3.6 pulley, a down pipe 180 degree t-stat, and a tune. Basically keep em' looking and sounding stock. Hope this answers your questions. Thanks for the responses, I look forward to your input.
  8. #8 Re: Should I Buy a GTP or GXP
    Oct 2011
    Toledo, OH
    Quote Originally Posted by GTP131 View Post
    The LS4 has DoD and doesn't require premium fuel, and has a higher EPA est MPG.
    Other than that, get a GTP
    7"
  9. #9 Re: Should I Buy a GTP or GXP
    Good luck getting better mpg with a gxp i dont care what the factory rating was.
    gtp all day everyday cheaper parts easier to work on easier to find go fast parts.
    plus how often do you see used go fast parts in the classifieds for a gxp? <<<<<< that should be reason number one not to get a gxp... well at least it is in my world. HA!
  10. #10 Re: Should I Buy a GTP or GXP
    Enfield, CT
    GTP for economy and and options for power
  11. #11 Re: Should I Buy a GTP or GXP
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Isn't DoD bad on the TC?
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  12. #12 Re: Should I Buy a GTP or GXP
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by industrialfish View Post
    Bro the ls4 most certainly does require premium fuel. I ran 91 and even 89 for awhile until I knew and saw more KR then I would of liked. Premium fuel...not really much of anything
  13. #13 Re: Should I Buy a GTP or GXP
    I break stuff selliott's Avatar
    Kansas City
    Gxp all the way in my book. But that's just me I already have a Gtp lol
  14. #14 Re: Should I Buy a GTP or GXP
    Jun 2012
    I'd never not buy a GXP
  15. #15 Re: Should I Buy a GTP or GXP
    I'd never buy a gxp unless I got a killer deal
  16. #16 Re: Should I Buy a GTP or GXP
    Never Never Land
    I can say for a fact my step mom's LS4 pulls 30 mpg at 75 mph. My GTP doesn't do that. At least stock it didn't. It might now with the intake/exhaust mods. Regardless. I'd go GXP if you don't want to mod. I think you'll like it much better in the end. They sound infinitely better. They're decently quick. Good on fuel despite what people say. And yes, slap a big ol trans cooler on there. Beings your'e looking at low mile cars I don't think you have to worry as much. It's not really hard parts that fail on GXP's, it's clutches burning up I think since they get so hot.
  17. #17 Re: Should I Buy a GTP or GXP
    Jun 2012
    Yea oil cooler, transforming shift kit, and every other year do a tranny fluid pan drop. And a catch can. All cheap things I consider maintenance and you'll be set
  18. #18 Re: Should I Buy a GTP or GXP
    Banned
    Jan 2013
    Colorado
    Quote Originally Posted by FordMan77 View Post
    G8 gt, gto...
    this, it should be a debate between the gt or gxp
  19. #19 Re: Should I Buy a GTP or GXP
    Kansas City
    I havent done any research but the LS platform has been around for a long time, i would think there would be lots of mods available or maybe I'm wrong?
  20. #20 Re: Should I Buy a GTP or GXP
    Jun 2012
    There's a good amount. But this ls4 isn't the most used block by far. Ls1 or 6 is what a lot choose. But honestly...nodding this ls costs about the same, actually a little cheaper, than other ls
