Thread: Rubbing noise when turning wheel
Results 1 to 16 of 16
  1. #1 Rubbing noise when turning wheel
    Nov 2011
    Indiana, PA
    This just started over the past couple weeks. When I turn my steering wheel I get a noise like you get when you rub textured vinyl together or a textured fabric like a jacket would have...
    I've already had my rack replaced, already had the steering pump replaced... they apparently packed the intermediate steering shaft with grease to reduce noise now this starts...
    any idea what it could be? It sounds like it is coming from inside the steering column itself almost.
    virtually every problem I've had with this car has came from the steering system....
    It's a 2008 Base GP
  2. #2 Re: Rubbing noise when turning wheel
    Enfield, CT
    did you get an alignment?
  3. #3 Re: Rubbing noise when turning wheel
    take the tire off on the side you hear it from, and look for a rub mark on the plastic shield. maybe its fallen out of place and rubs the tire when turning.
  4. #4 Re: Rubbing noise when turning wheel
    FWIW it'll be the right side
  5. #5 Re: Rubbing noise when turning wheel
    Nov 2011
    Indiana, PA
    Yes, I also replaced all tires and had a sway bar replaced on the front right. After all that, this started
  6. #6 Re: Rubbing noise when turning wheel
    Nov 2011
    Indiana, PA
    which plastic shield? the wheel well black plastic one? or another one that I'm not thinking of.
  7. #7 Re: Rubbing noise when turning wheel
    look over the whole wheel well, all the plastic. you'll see a rub mark if its hitting the tire. a screw or clip may have fallen out, or part just fell out of place.
  8. #8 Re: Rubbing noise when turning wheel
    Nov 2011
    Indiana, PA
    I don't see any loose plastic shields or anything else rubbing on a tire or any rods... any other ideas?
  9. #9 Re: Rubbing noise when turning wheel
    the brake rotor has a dust shield its metal. sometimes they get bent a bit and touch the rotor and make noise, other then that im out of ideas.
  10. #10 Re: Rubbing noise when turning wheel
    Nov 2011
    Indiana, PA
    checked the steering fluid again, it's still at the perfect level....
    turned the wheel slowly and listened around it, it actually sounds like the noise is coming from inside the column... what all is in there that might rub ever? because the closer to the wheel the louder it is, the closer I get to the floor boards the less I can hear it.
  11. #11 Re: Rubbing noise when turning wheel
    pretty sure the column shaft runs through 2 bearings, maybe one is dry? not sure really.
  12. #12 Re: Rubbing noise when turning wheel
    SE Level Member georgeo's Avatar
    Jun 2014
    Colorado
    I had a 77 Cutlass that I had to replace the steering column in. The replacement came from a 77 Monte Carlo. None of that really matters except that when I finished the swap I had a rubbing noise int he column and it was only dry bearings. Not sure if they use a sealed unit in the newer stuff or the bearings are still the captive ball type. A shot of grease or graphite to the bearing worked for me.
    And if the mechanic had the column out, make sure the wire harness isn't rubbing on the turn shaft. Big problems later on!
  13. #13 Re: Rubbing noise when turning wheel
    Dec 2012
    Where 4T65E's were born
    Look at the steering column and make sure the rubber sleeve that's around it isn't pinched and rubbing on anything. Our impala makes a slight squeaking noise from the inside when turning, I'm not sure what it is yet but I'll look into what I said.
    Sold.
  14. #14 Re: Rubbing noise when turning wheel
    Jan 2014
    AR
    Are there any dash warning lamps on? Has the car ever been in an accident with airbag deployed or with impact on a front wheel? I think I would want to do an exploratory teardown- remove the steering wheel and column trim just to see if the noise becomes obvious then. Hopefully something just needs to be shoved out of the way. For what it's worth, a LOT of cars make a little noise when turning the wheel. Be sure not to fix it if it ain't broke!
  15. #15 Re: Rubbing noise when turning wheel
    Nov 2011
    Indiana, PA
    No, there are no warning lights, it did have a rear impact about 8 months ago and had to have the rear panel replaced and a new trunk lid, but after that I didn't have a noise. The car was completely realigned after that, everything was inspected, etc. This noise just started in the past few weeks, I never heard it in the entire time I owned this car since it came off the assembly line.
  16. #16 Re: Rubbing noise when turning wheel
    Jan 2014
    AR
    OK then. I asked about the SIR system because theres a clockspring in the column and it is possible for them to make noise, especially if re-used after a deployment. Not being able to see / hear it myself, my only other suggestion is to check with a GM dealer to see if any bulletins (known issues with established fixes recommended by GM) exist concerning your issue.
  1. Clicking noise when turning wheel
    By afallucco in forum Brakes/Suspension/Chassis
    Last Post: 10-13-2013, 10:16 PM
  2. Popping/rubbing sound while turning right
    By CapnBreakAlot in forum General Tech Discussion
    Last Post: 04-30-2013, 01:52 PM
  3. Clunking noise when turning wheel?
    By Hippo Machine in forum General Tech Discussion
    Last Post: 09-16-2012, 02:02 PM
  4. Rubbing noise
    By cruzn in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2011, 09:56 PM
  5. Odd noise / rubbing
    By Elitemonkie in forum General Tech Discussion
    Last Post: 11-06-2010, 08:06 AM
