Thread: Car sounds like a prop plane...
Results 1 to 20 of 21
  1. #1 Car sounds like a prop plane...
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    Okay, sooo....I think my car is trying to impress me by doing its best impersonation of a world war II era fighter plane. As I'm driving, it almost sounds like a propeller plane. The sound follows the vehicle speed, not the RPMs. The car still acts the way it always has - no change in how it shifts, performs, fuel efficiency, nothing...just makes this airplane type sound. Thoughts on what it might be???
  2. #2 Re: Car sounds like a prop plane...
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    I gotta hear a video of this.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Car sounds like a prop plane...
    SE Level Member A98GTP's Avatar
    Apr 2014
    Texas
    Yeah only things i would even know to check are the blower motor and make sure the fan isnt clipping the shroud but neither of those would be speed dependant
  4. #4 Re: Car sounds like a prop plane...
    HUDSON
    Tire or wheel bearing. On a more rare possibility the reluctor ring on the differential has been known to move and contact the diff. housing (alum.), the notches of the metal ring hitting the alum. cover could make the sound you describe also.
  5. #5 Re: Car sounds like a prop plane...
    Apr 2014
    Texas
    Wheel bearing usually constant noise not prop plane kinda noise though. Could see a knot on the tire causing the noise maybe but it would shake like all hell while driving. Haven't ever experienced the reluctor ring issue to know what it would sound like personally.
  6. #6 Re: Car sounds like a prop plane...
    Apr 2012
    Dayton, OH
    Make sure non of the springs broke and twisted around destroying your tire.
    2012 F150 STX
  7. #7 Re: Car sounds like a prop plane...
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Maybe your plastic inner fender liner has come loose and is rubbing , you know like putting a playing card in your bicycle spokes. Man I'm old. lol
  8. #8 Re: Car sounds like a prop plane...
    Chicago
    It could be wheel bearings as mentioned earlier. I tried searching for my audio clip when I had the problem but could not find it. Basically it sounded like I was driving a 4x4 with huge knobby tires. Aside form the noise there were no other noticeable impacts to how the car drove.
  9. #9 Re: Car sounds like a prop plane...
    Feb 2013
    37.295091, -121.930053
    i want a video!! reason beening i been near ww2 planes hell my grandpa built a few planes so i would know from first hand what a real plane sounds like lol
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  10. #10 Re: Car sounds like a prop plane...
    Delaware County, PA
    I am having the same issue on my '07 GT. Started like road noise last week, then started buzzing. Speed related; most noticeable between 35-55mph, not engine/trans rpm. Doesn't make the noise idling. I've had wheel bearings go before but that was more of a grinding noise. The buzzing does sound like a prop plane.
  11. #11 Re: Car sounds like a prop plane...
    Chicago
    One more thing to add if it is bearings from experience. Both my wheels had slight play when I would grab the wheel in both the 12 and 6 o'clock position as well the 9 and 3 o'clock position. You could feel a very small click when tugged side to side. Remember to try both positions to avoid mistaking cause due to other worn suspension components like a lower ball joint or outer tie rod end.
  12. #12 Re: Car sounds like a prop plane...
    Oct 2012
    Union, OH
    I put that because the sound reminds me of old WWII movies showing the fighters in formation, and the sound effect used for that...lol
  13. #13 Re: Car sounds like a prop plane...
    Oct 2012
    Union, OH
    Do axles/CV joints make noises like this when they go bad?
  14. #14 Re: Car sounds like a prop plane...
    Apr 2014
    Texas
    axles/cv joints usually start popping when they start going out. Easy way to check the cv joints is cut the wheel all the way over to each side and take off. If you hear a pop pop pop its bad.
  15. #15 Re: Car sounds like a prop plane...
    Oct 2012
    Union, OH
    Okay - I think I'm good there then.
  16. #16 Re: Car sounds like a prop plane...
    Oct 2012
    Union, OH
    I'm thinking it's the right side hub...when I go around right hand curves, the sound lightens up a bit as the pressure comes off of that right front tire...when I straighten back out, it comes back in full volume. When I go around left hand curves, the sound stays the same volume. I'll jack up the front end today and see what's moving.
  17. #17 Re: Car sounds like a prop plane...
    Apr 2009
    Maine
    Mine is doing this right now. I'm fairly certain it's the drivers side wheel bearing. Picking up new hubs for both sides after work. I thought mine was a tire rubbing at first because it started just after I put my summer wheels on, but I checked and everything looks fine.
  18. #18 Re: Car sounds like a prop plane...
    Delaware County, PA
    Mine is getting louder every day and it's almost drowning out the radio; it's so loud. First chance to look at it is Saturday and I drive 50-60 miles a day; mostly highway. Am I going to do any additional damage over the next couple of days if it is the bearing?
  19. #19 Re: Car sounds like a prop plane...
    Apr 2009
    Maine
    I put a new wheel hub on last night. Problem solved. Pretty easy job too besides some stubborn bolts.
  20. #20 Re: Car sounds like a prop plane...
    SE Level Member eastcoastcam's Avatar
    Feb 2013
    Beaverbank, Nova Scotia
    I just posted up the same problem last night. I thought it was my DS CV axle, and turns out it is the wheel bearing.
    ...back to the parts store...
    My wife loves her GP. But I'll keep my Jeep
  1. safe to drive with broken hood prop?
    By PhunnyJesta in forum General Tech Discussion
    Last Post: 10-11-2012, 08:45 PM
  2. More Sounds...
    By Remnant King in forum General Tech Discussion
    Last Post: 02-17-2012, 01:10 PM
  3. Prop Rod
    By Guiltyr1 in forum General Grand Prix Discussion
    Last Post: 01-26-2012, 05:34 AM
  4. hood strut arm prop
    By dpzelenak in forum Off Topic Discussion
    Last Post: 05-12-2011, 10:49 PM
  5. Intentional plane crash in texas
    By Toofastgs in forum Off Topic Discussion
    Last Post: 02-21-2010, 08:16 PM
