Thread: help with oil leak around pan
Results 1 to 11 of 11
  1. #1 help with oil leak around pan
    SE Level Member MJCULE's Avatar
    Feb 2013
    Buffalo, NY
    Hi I have a 2004 GP GT1 and I noticed that I was losing some oil after I was finding little spots in my driveway. I took it to my local garage who are usually good about things and they said that they didn't notice anything out of the ordinary. I find that hard to believe after I went under the car myself and found the whole pan was covered in oil. Even more was at the top of the pan where the bolts/screws connect (I believe there is a gasket there) as those screws are soaked in oil. Is there a gasket there? Am I in the market for a new oil pan? Or is he right and is this normal? attached are a couple pictures that show the leaking.
  2. #2 Re: help with oil leak around pan
    Classic oil pan gasket seep.
    You can clean it all off and see how long it takes to come back if you wanted.
    Otherwise it's time for a new gasket, I know the labor on one isnt very cheap.
  3. #3 Re: help with oil leak around pan
    looks just like mine
    with a flash light look up past the oil pan on the block, look for a oil trail up to the valve cover, same with the back side. vc leaks can look just like that.
    you can also take a clean paprer towel and fold it up and wipe under the lower lip of the valve cover, if it comes back wet with oil you found a leak.
  4. #4 Re: help with oil leak around pan
    GT Level Member MCbatt's Avatar
    Oct 2013
    MARYLAND
    That's what mine looked like a month or so ago. I had t replace the gasket and that's not a very fun job. Would you be taking it to a shop to get it changed or doing it yourself? Not fun to do yourself but pretty expensive at a shop to get it done like fivefingerdeathpunch said.
    Courage is fear hanging on a moment longer.
    -Thomas Fuller-
  5. #5 Re: help with oil leak around pan
    SE Level Member dknight's Avatar
    Mississippi
    I took mine to a shop to have the oil pan gasket replaced and front seal replaced. They had to drop the spindle to remove the oil pan so they had to do an alignment too. I had a leak in an a/c too, just the low pressure orifice. Cost $700 for all.
  6. #6 Re: help with oil leak around pan
    Feb 2013
    Buffalo, NY
    Quote Originally Posted by MCbatt View Post
    I'm going to call around tomorrow and see if I can find some prices. It would be about $150 for parts and tool rental so depending on how much places around here (Buffalo) want to charge for labor since I know there's some work that goes into it I am going to make a decision based on price. If its $300-400 I might just have them do it but if it's anything more than that (like $700) I think I would give it a try myself
  7. #7 Re: help with oil leak around pan
    Feb 2013
    Buffalo, NY
    Quote Originally Posted by dknight View Post
    Do you know how much it would of been just for that alone minus the A/C
  8. #8 Re: help with oil leak around pan
    Maybe 400-500, just a guess.
    It's pretty much an all labor job, the part costs maybe 20-40 bucks for a nice gasket.
  9. #9 Re: help with oil leak around pan
    Mississippi
    I looked for my receipt but I couldn't find it. I don't remember what they quoted me before I got it done, either. I also had the oil pan gasket I bought from a parts store too. Best thing would probably be to call around for a quote.
  10. #10 Re: help with oil leak around pan
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    Mine is gonzo as well. My engine and trans are coming out this summer for oil pan gasket, cam, front main, rear main, and head gaskets / head studs.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  11. #11 Re: help with oil leak around pan
    ... osiris94ej's Avatar
    Sep 2012
    Casper Wyoming
    Labor time is 4.5 hours. It all depends on what that particular shop charges for the part's, their hourly labor rate, and if they charge a shop charge/disposal fee's. I run a small shop and the shop labor rate is $50/hr. Look for a well recommended independent shop or smaller shop and you will usually get it done for cheaper.
    Here is what it would cost from my shop.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
