Thread: is this knock, misfire, fuel, ICM, or...?
Results 1 to 2 of 2
  1. #1 is this knock, misfire, fuel, ICM, or...?
    May 2012
    Grand Forks, ND
    So, got a 99 GTP, and every once in a while under 70% or more throttle, 2nd gear or higher, it gives what I would call one @#$%ing hard miss with no SES light or codes when it's -20F outside or +100F. Here's what I know of the motor/trans; it looked stock but replaced a drilled 165* thermo with 180, wouldn't warm up in winter in nw Minnesota and I didn't know better, leaked oil everywhere and blew every oil gasket when I first used royal piss, wont use that junk again, when all gaskets replaced including supposed recalled ones(they weren't), the mech said I had internals he didn't recognize as stock, and SC pulley was beat up.
    What I did: first two things, headers and dp, CAI, U-bend resonator delete, used Corvette 3" cat and 3" pipes straight to Y pipe, and factory pipes to fac mufflers. Second was coils/wires/plugs; msd/msd/AL iridium xp's like factory says. New fuel pump/filter, flushed it all the way to rails, tran filter, cooling system flush, PS flush, brake line flush plus cross drilled/slotted 12" upgrade. Replaced with 33# inj. It did have a 1.0 from zzp that I didn't know, dealer fixed that @#$%&*... so my question is, plugs?104's waiting, arms are too big to reach, fuel? We only have 91 or 100 race gas. Fuel pump wired for more V, and volt booster. The msd coils have been good, I think, 20000 miles on them, or ICM? no ses light tho. Confused and frigid, any help?
  2. #2 Re: is this knock, misfire, fuel, ICM, or...?
    Donating Users timboku's Avatar
    Montgomery, IL
    Do you have anything to scan for kr? Maybe knock.but when.temp was minus 10 I couldnt give it more than 60percent gas or it would buck and tey to.cut out..after replacing plugs, wires, fuel.pump, and fuel filter with no change, I swapped in a used icm and it ran better, than regappwd plugs to .42 and now runs perfect. Id check.the icm mine had about 200k on it.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  1. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  2. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  3. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  4. Knock because of crank pulley or fuel pump
    By comongoose in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2009, 10:27 AM
