Thread: Vacuum leak
Results 1 to 5 of 5
  1. #1 Vacuum leak
    Feb 2014
    Colorado
    Hey guys I have an '02 3.1L GP. A while back I got the check engine light saying vac leak (440). Since I remember not closing the gas cap all the way earlier, I assumed it was that, but I replaced the cap with a new one anyway and reset the light. Then about a week later the light came back on with the same code: vac leak (440). But I don't think it's the gas cap because a) it's new and b) there is a strong smell of gas in the car when idling. Any ideas?
  2. #2 Re: Vacuum leak
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by Kellson View Post
    A vac leak is under the hood. Check the rubber hoses, plastic pieces, etc. the fuel smell is from the car running pig rich.
    it never was the gas cap. (Perhaps someone has a vacuum diagram of the 3.1?)
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  3. #3 Re: Vacuum leak
    http://www.obd-codes.com/p0440 the purge solenoid may be bad. i had this one a while back.
  4. #4 Re: Vacuum leak
    Jun 2011
    Texas
    If you have a strong smell of gas, look for the source of the smell. P0440 is generally described as a large evaporative emissions leak. A fuel leak can cause the gas smell and the P0440.
  5. #5 Re: Vacuum leak
    Feb 2014
    Colorado
    There's no fuel leak, no decrease in fuel economy. The car is also not running rich—again fuel economy is good and there is no roughness. Must be somewhere with fuel vapors. EVAP canister? I think the purge solenoid could be right
  1. Vacuum Leak?
    By Oilcan in forum Engine
    Last Post: 11-03-2013, 09:00 PM
  2. Vacuum Leak?
    By crock in forum General Tech Discussion
    Last Post: 08-21-2011, 12:09 AM
  3. vacuum leak or bad egr
    By mjdennis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2010, 10:49 PM
  4. vacuum leak?
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2010, 01:27 PM
  5. Bad vacuum leak
    By boredout in forum General Tech Discussion
    Last Post: 07-14-2008, 02:21 AM
