Thread: Old Thread
Results 1 to 5 of 5
  1. #1 Old Thread
    USA
    Old Thread
  2. #2 Re: Rapid Passenger Turn Signal (Bulbs working Fine)
    what year is your car? sounds like a flasher relay too a dump.
  3. #3 Re: Rapid Passenger Turn Signal (Bulbs working Fine)
    that year the what ever they are calling a flasher seems to be built into the multi switch.
    make sure the socket its good, swap bulbs form one side to the other.
    i had a bad front socket, was causing the hyper flash. the socket kept breaking the metal wire on the end of the bulb. new socket, all better now.
  4. #4 Re: Rapid Passenger Turn Signal (Bulbs working Fine)
    turn the signal on, and play with the front and rear bulbs, wiggle them pull them out a l little push em in hard. see if they slow back down.
    wear gloves, those bulbs get hot pretty fast.
    and yup that it, the turn signal lever and all. make sure if you order one its got all the same functions that yours does.
  5. #5 Re: Rapid Passenger Turn Signal (Bulbs working Fine)
    not sure, pull em all out and check them.
  1. Turn Signal blinking fast but hazard lights are fine? All stock, no LED's.
    By TwistedMexi in forum General Tech Discussion
    Last Post: 03-31-2013, 10:13 PM
  2. led turn signal bulbs
    By Matt Palm in forum Audio, Security & Visual Electronics
    Last Post: 02-15-2013, 03:57 PM
  3. Turn Signal not working
    By FX4 Level II in forum General Tech Discussion
    Last Post: 03-19-2012, 08:04 AM
  4. pink/purple turn signal bulbs
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 03-13-2010, 12:43 AM
