Thread: 2007 Grand Prix stalls after warm start
Results 1 to 12 of 12
  1. #1 2007 Grand Prix stalls after warm start
    Jul 2012
    Bloomington, IL
    I have a 2007 Grand Prix with 160,000 miles on it, and it starts just fine when the engine is cool. However, if I run to the store for 10 - 15 minutes, and then come out and try to start it again, it will turnover and then stall immediately. If I give it some gas after starting it, then it's fine and will continue to run.
    I've looked around the internet a little, and I see some say it's the CPS, or the ICM. This same thing happened on a 2005 Grand Prix that I had with a lot of miles. Coincidence?
    Jeff
  2. #2 Re: 2007 Grand Prix stalls after warm start
    start with a Throttle body cleaning. i bet its filthy.
    the cps and icm would make it misfore, or stall while its running.
  3. #3 Re: 2007 Grand Prix stalls after warm start
    Jul 2012
    Bloomington, IL
    Is it recommended to remove the TB completely? Or to just clean what you can after disconnecting the air flow line?
    I've never removed one before, so how difficult is it to remove one on the '07 GP?
  4. #4 Re: 2007 Grand Prix stalls after warm start
    take the air filter tube off open the flap inside, the carbon build up is behind that brass flap. clean the sides of that flap and the back of it, and as far back and around the walls as you can. a old tooth brush and a rag work well to clean it up.
    if you want to take it off you just un plug the sensors, and un bolt it, some coolant will spill out, this is normal. then clean it up in hand.
    carb cleaner cleans it up nice too.
  5. #5 Re: 2007 Grand Prix stalls after warm start
    Jul 2012
    Bloomington, IL
    Thanks. It won't hurt anything to manually open the brass flap to get back in there?
  6. #6 Re: 2007 Grand Prix stalls after warm start
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    nope I have done this several time to my 04 and 07
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  7. #7 Re: 2007 Grand Prix stalls after warm start
    Jul 2012
    Bloomington, IL
    Have you experienced the same stalling issues after the engine is warm?
    It will only stall when starting it after it is warm, but if you give it some gas before it stalls, then it will stay running after that.
  8. #8 Re: 2007 Grand Prix stalls after warm start
    Nov 2013
    Des Moines, IA
    Cold starts she would fire right up but if I drove for a bit ect. it would die it almost sounds like it starving for fuel or something but its really choking for air because the carbon build up is blocking the slight crack in the TB the car needs to idle. Just clean her up. you will be amazed the difference it makes its pretty cool.
    2007GPGTSC
    " sad thing is "
  9. #9 Re: 2007 Grand Prix stalls after warm start
    Jul 2012
    Bloomington, IL
    This may be a dumb question, but are the TB's the same for all 04+ models? So if there was a video on how to remove and clean the TB for a 2004 GTP, would that be the same process for an '05 or '07?
  10. #10 Re: 2007 Grand Prix stalls after warm start
    Yup, tb is the same.
  11. #11 Re: 2007 Grand Prix stalls after warm start
    Pennsylvania
    Just pull it off the car, it's 4 bolts and you can get both sides of the plate and the bore itself a lot easier... just takes a second.
    Sport Edition Kv5 18x8
  12. #12 Re: 2007 Grand Prix stalls after warm start
    Jul 2012
    Bloomington, IL
    Well, we spent about 3 hours cleaning the TB (both sides) and as far inside as we could (engine side). I could not believe the buildup. I stuck the rag in on the engine side, and I actually pulled out a small chunk that was pretty much covering that little hole. (Sorry, I don't know the official term for that). We scrubbed and scrubbed, and probably used about 3/4 of the CRC TB cleaner can. The TB looked was almost new after we were done, and we did the best that we could engine side.
    The difference in the way it starts and runs now is like night and day. No more stalling after re-starting warm, or having to give it gas to keep it running. And we can even use the remote start now.
    We also cleaned the MAF while we had it out.
    I'll need another can of the TB cleaner before I do my own 2005 GTP. It shouldn't be as bad since I just hit 80k.
    Thanks again for everyone's input on this. It truly made the difference.
  1. 2007 Pontiac grand prix remote start problems
    By 1lofton in forum General Grand Prix Discussion
    Last Post: 02-02-2013, 01:15 PM
  2. Owned 91 Grand prix 22 years ,hard start & stalls
    By traveltech in forum General Grand Prix Discussion
    Last Post: 09-12-2012, 11:40 AM
  3. PLEASE HELP!!!Grand prix won't start when warm unless pumping the gas pedal..
    By hockeybawler in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2012, 10:22 AM
  4. '01 Grand Prix GTP won't start and stalls
    By tmac10 in forum General Tech Discussion
    Last Post: 12-02-2010, 10:26 AM
  5. 1998 Gd Prix sputters and stalls when engine warm
    By jmickevi in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-18-2010, 02:05 AM
