Thread: Heat issue grandprix 2008 3.8
Results 41 to 60 of 71
  1. #41 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    When I run water In both directions I assume I want to leave the water in there as I do not want to get air in the hose
  2. #42 Re: Heat issue grandprix 2008 3.8
    id just flush one hose till coolant or water comes out the other, then put the hoses back on as full of water as you can. why put a hose back on thats full of air already right?
  3. #43 Re: Heat issue grandprix 2008 3.8
    Dec 2012
    Where 4T65E's were born
    Where does your temp gauge stay on the real cold days?
    Sold.
  4. #44 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    Just right at the first line of the temo gauge
  5. #45 Re: Heat issue grandprix 2008 3.8
    try bleeding the t stat housing. you may have some air trapped in the lim as well.
  6. #46 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    I just flushed the heating core, will see how that goes, Will report back.
  7. #47 Re: Heat issue grandprix 2008 3.8
    you can also touch both heater core hoses after its warmed up good. if both are hot you fixed it.
    if one is hot, one cold, its not pumping still for some reason.
    these hoses can get damn hot, dont get burned. do the quick touch test first.
  8. #48 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    I did touch the hoses when I flushed it, both hose didn't get no where near hot to the touch.
  9. #49 Re: Heat issue grandprix 2008 3.8
    car has to get up in temps for then to get real hot like they should be.
    what temp t stat you running? being up north there you should be running a 195.
  10. #50 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    How can I tell what temp it's running at. Does it say on the console?
  11. #51 Re: Heat issue grandprix 2008 3.8
    your temp gauge on the dash should tell you. when its like 2 or 3 lines from red thats your normal area on most gp's, in america, i dont do metric well lol
    my regal needle is one line under the 1/2 way mark, thats about 200 degrees.
  12. #52 Re: Heat issue grandprix 2008 3.8
    if you have a torque app it will tell you the temp as well in digital read out, so you know exactly whats its reading vs lines on a gauge in the dash.
    like so, this was a real hot day parked with the a/c on full blast. love that 158 intake temp lol
  13. #53 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    I do have the torque app will run it later
  14. #54 Re: Heat issue grandprix 2008 3.8
    Mar 2015
    Erie,PA
    Change out the thermostat also. They are cheap, only two bolts and make sure to get a 195F one instead of 212F.
  15. #55 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    Thermostat was already changed when I had it flushed in November
  16. #56 Re: Heat issue grandprix 2008 3.8
    Mar 2015
    Erie,PA
    Gotcha, what temperature is the air coming out of the vents? I just checked mine at 90F on a 22F degree day, after sitting for a half hour cooling down and then starting back up for about 5 minutes, this is with fan on about halfway, temp all the way up, recirc on and the position was full on vents.
  17. #57 Re: Heat issue grandprix 2008 3.8
    if a shop changed it see if it says what temp they used on the receipt. if its a 180 that can keep your temps pretty low in winter time.
    195 is stock. i dont think anyone sells a 212 lol a 195 lets the engine run around 200 to 210 ish, where gm wants its it to run. your hi speed fan setting is 212 too.
  18. #58 Re: Heat issue grandprix 2008 3.8
    Mar 2015
    Erie,PA
    Really, mine came stock with a 212F one. Well It was built in Canada, so maybe it was a mixup with a cold weather equipped car. Who knows? It currently is running a 195F and couldn't be happier. I get blow dryer type heat in about 10 minutes even at the -0F temperatures Dreary Erie is famous for.
  19. #59 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    Will take a reading on the torque app and I will also check the temperature inside after I drive to work tomorrow, it's a good 25mins drive.
  20. #60 Re: Heat issue grandprix 2008 3.8
    Mar 2013
    Canada
    I gave it another flush and actual small rocks came out of the hose, I let the car run and the heat seems a lot hotter. Here is the torque app result
  1. 2008 Grand Prix heat is starting to fail
    By veener79 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2013, 08:04 PM
  2. My 2008 GrandPrix GXP
    By Bobbie Graves in forum Introductions/Noob Questions
    Last Post: 01-09-2013, 10:05 PM
  3. 2000 grandprix gt tranny issue
    By mattstansbury in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2011, 09:33 PM
  4. Engine whine!! 2008 grandprix gxp 5.3 v8
    By tonio301 in forum 5.3L V8 (LS4)
    Last Post: 06-07-2011, 10:43 AM
  5. 2008 Grandprix 56K Miles-- Wheel Bearings replacement.
    By magickid in forum Tires & Wheels
    Last Post: 04-09-2011, 07:25 PM
