Thread: Intense PCM
Results 1 to 5 of 5
  1. #1 Intense PCM
    Dec 2013
    Illinois
    I bought my 02 gtp and it already had an Intense PCM, colder t*, k&n intake, etc. I now
    am having the p0420 and want to know if i can tune it out or not. And if i cannot, how bad would putting
    in a ZZP pcm be on my vehicle if it's had the Intense PCM for quite some time.
  2. #2 Re: Intense PCM
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Quote Originally Posted by tbrown1309 View Post
    P0420 is likely a vacuum leak, not a PCM issue. Check your vac hoses and replace if needed, the car is twelve years old by now. Other possible sources of vac leaks include the EGR passage, the S/C gasket, and the boost bypass valve.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  3. #3 Re: Intense PCM
    Florida
    Uh p0420 is the cat code bruh. Bad/clogged cat,or failing o2 sensor. Or even having a high flow cat.
  4. #4 Re: Intense PCM
    Jul 2012
    Chicago
    Sounds like you need the code deleted.
    -Carl
  5. #5 Re: Intense PCM
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    i bought my 01 with an intense PCM. the p0420 code came up and i deleted it and it never cam back again.. I'm not sure if the pcm did something or i just got lucky... just putting it out on the table
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  1. Intense G8 GT
    By UR LOSN in forum Other Vehicles
    Last Post: 10-11-2010, 09:08 AM
  2. intense pcm?
    By shawn3091 in forum Off Topic Discussion
    Last Post: 01-02-2010, 06:11 PM
  3. Intense PCM
    By JB Miller in forum General Tech Discussion
    Last Post: 05-14-2009, 10:45 AM
  4. Intense MPS vs. ZZP MPS
    By 04CompG in forum General Tech Discussion
    Last Post: 10-07-2008, 05:03 PM
