Thread: Old Thread
Page 1 of 8 123 ... LastLast
Results 1 to 20 of 159
  1. #1 Old Thread
    USA
    Old Thread
  2. #2 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    gardner,mass
    Not a bad idea. If you gonna have your hood painted get a sexy new one
    That being said.
    I own a grand prix.
    Ill fix it by getting something else when im rich.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    It's resale value is $0 so that's a problem.
    04 Comp G.
  4. #4 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    gardner,mass
    I said when im rich so ill just burn it.
  5. #5 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Dec 2011
    Philadelphia, PA
    my chugging/hesitation problem with my shifting, not exactly sure whats wrong with it so i have no idea how to fix it and dont have the money to
    my abs is going, also dont have the money to fix it so cant really do anything about that either
    car is getting 16 mpg, so that aint right so im sure theres something going on there that idk about
    breaks make a screeching noise mostly when backing up, have no idea the problem with that and ALSO dont have the money to fix it haha so yea fml/****ty salary
    AEM bruteforce intake
    Diablo 93 Octane tune
  6. #6 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Apr 2012
    Goderich, Ontario
    Think I need an ignition switch. Heater and headlights randomly work sometimes. Think I need an alignment, my steering wheel is a lil sideways. Also my wife's 02GT needs brake lines, I think. I've toped up the master cilinder twice in 3 weeks and that's defiantly getting fixed this week.
    -Paul Walker
  7. #7 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    GTP Level Member speed demon's Avatar
    Apr 2011
    MICHIGAN
    Trans is dead due to forward band being broke ( f***ing 01's) and has been down for way to long!
    Plans- complete rebuild,300m shaft,hardened 4th,transgo shift kit,new tq converter (stock stall) plus all the other upgrades to the valve body.
    Body work-shaved front and rear bumpers,due to both are going through the notorious clear coat peel.
    All of this will be done as soon as my little 1yr old gremlin stops taking all of my money...lol,i swear everytime she touches water she grows another inch.
    '01 GTP: Rebuilt Trans by Andrew S....300m,hardened 4th,Transgo shift kit,V8 chain ect ect,3.8 MPS,ZZP 10.5.....More to come!
  8. #8 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    It's messy inside. I'll clean it this weekend. Beyond that, there's no issue that can't be fixed by turning up the radio or filling the tank.
  9. #9 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    In no particular order:
    Cruise control hasn't worked since about two days after I bought the dang thing.
    ABS/TCS lights came on as soon as I installed an A/C compressor. I think I crushed a wire while reinstalling my too-big battery. Electrical tape covers up those lights nicely.
    One of the fog lights is out, I haven't gotten around to fixing it yet. Probably just a bulb.
    I've got the typical rocker panel/rear strut tower issues. Going to have to cut and weld patches onto them probably next spring.
    Sunroof leaks when I park downhill and it rains heavily. Probably a clogged drain line or headliner acting dumb. I haven't had a chance to take that apart yet.
    All four struts are worse than useless. I only go fast in straight lines. Probably a spring 2014 project.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  10. #10 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Panda needs to go to its new home.
    and my Saab is perfect
  11. #11 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    my front brakes squeal and everything looks perfect when i take them apart. it's ****ing annoying.
  12. #12 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Aug 2011
    'Merica
    Trans line leaks a little when the car is turned off (Bill has told me how to fix this), rattle in the rear somewhere is causing the driver side rear tire to wear funny, 4 DTC's that need to go away, alignment needed, and need to fix the bulbs in the radio (might put in an aux port while I have the head unit out. I think that is all......for now
  13. #13 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    scuff rotors and rebed pads
  14. #14 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
  15. #15 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Needs an alignment. A new trans mount. Has some rust starting on top of the driver's side rocker, yet it is not bad underneath... lol. Some cute little bubbles near the gas tank. Few small dents. It's been through a lot lol. Oh, and the a/c doesn't work!
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  16. #16 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    SE Level Member jjmitch87's Avatar
    May 2013
    Boston MA
    need to flush out the cooling system as i found dex sludge in my radiator and reservoir tank. whats weird is only green coolant came out when i took my plastic elbows off to do my power steering pump... TWICE (GRR) but it seems like its filled with dex in the rad *shrug*
    pinhole leak in the hose from rad to reservoir tank.
    would like to change the s/c oil.
    new air filter as mine is beyond help.
    reconnect the wires to one of the knock sensors- the one by the ps pump. whoever is the genius that decided to tangle those wires up with the ps pump lines theres a special place in hell for you.
    new tire because one has a flat spot and its annoying- will probably wait till summer2014 and just get 4 new tires.
    2001 Grand Prix GTP, silver w/ black hood, silver bullit 17s
  17. #17 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Howell, NJ
    Random misfires
    Bad engine mount
    Bad struts
    Fog light out.
  18. #18 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Banned
    Oct 2013
    Moorhead, MN
    Rust.
  19. #19 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    I need
    Drivers side lower control arm
    Drivers side tie rod end
    Steering rack
    Struts and springs
    Front sway bar
    Front tires.
  20. #20 Re: The "Whats Wrong With Your Car Thread" Post Your Issues Here
    Donating Users Jordan's Avatar
    Oct 2011
    Richland Center, WI
    GXP:
    Front bumper needs repainted
    Needs touch ups on paint all around
    Needs bushings
    Exhaust leak
    Comp G:
    Burns a **** ton of oil
    starting to rust
    Check gas cap alert keeps coming on
    And now it's having troubles starting cold. Like it isn't getting enough fuel.
    2009 Cobalt SS/TC Coupe |
    Summit White | 131k | ZZP charge pipes, ZZP heat exchanger, ZZP 3" downpipe, HP tuned, Muffler delete, K&N Typhoon intake, dual interceptors, retrofits with switchback halos
    2006 Grand Prix GXP | Black | 95k
  1. "wrong" struts wanted for front of 97GTP to raise it..
    By darkhorizon in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2013, 07:47 PM
  2. Replies: 3
    Last Post: 07-15-2013, 12:53 AM
  3. Can't post a New Thread in the "For Sale - Vehicles"
    By sandite5 in forum Off Topic Discussion
    Last Post: 06-04-2010, 05:30 PM
  4. Not letting me post a "For Sale" thread! WTF?
    By 01SmokedGtP in forum Introductions/Noob Questions
    Last Post: 04-29-2010, 10:13 PM
