Thread: Won't shift out of park
Results 1 to 16 of 16
  1. #1 Won't shift out of park
    GTX Level Member AKGTP19's Avatar
    Mar 2013
    Fort Lauderdale, FL
    So i cant shift out of park unless i press.. which i believe is the override.. in to the left while pressing the shifter button to get it out of park, will shift fine into all the other gears, 98 GTP, i think it might be the shift lock solenoid but there are many things it could be down there. the fuze for the BTSI is good, so im stuck at this point..
    1998 GTP Loudmouth
    1999 GTP, Borla Cat Back.....SOLD
  2. #2 Re: Won't shift out of park
    if you take the console out, on the shiftier is a plug, this plugs wires can break off or get damaged.
    theres a post here where a guy is selling the metal pins, so you re pin the bad wire, and push it into the plug, aka good as new. its got a vid with it, and its not in the how to section. i think its some where in general maint.
    if the wires look ok the solenoid on the shiftier could be dead, and im pretty sure its part of the shiftier, so junk yard is the cheap way if it comes to that.
  3. #3 Re: Won't shift out of park
    Mar 2013
    Fort Lauderdale, FL
    what if i was to remove the solenoid and drive without it? i believe it just doesnt require brake to put it in and out of park if you remove it?
    1998 GTP Loudmouth
  4. #4 Re: Won't shift out of park
    Jan 2012
    Philadelphia
    I had the same problem and I replaces the harness that goes to the shifter and now it works fine, check all your wires and make sure there good
  5. #5 Re: Won't shift out of park
    Mar 2013
    Fort Lauderdale, FL
    I had another weird malfunction, I stepped on the gas in 1st and when it was getting to mid-high rpm's, it sounded like backfiring but it was also like hesitating to shift and like not providing all the power, TC? Maybe even a blower problem? Could be anything but it's not normal again..
    1998 GTP Loudmouth
  6. #6 Re: Won't shift out of park
    GTX Level Member crbquist's Avatar
    Massachusetts
    I had the same problem. Take the shifter apart and look for wires that could have split, then solder back together.
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  7. #7 Re: Won't shift out of park
    Mar 2013
    Fort Lauderdale, FL
    Fixed it, orange wire was split in half, reconnected with thicker wire an she's golden
    1998 GTP Loudmouth
  8. #8 Re: Won't shift out of park
    amazing how that happens all by its self aint it.
  9. #9 Re: Won't shift out of park
    Mar 2013
    Fort Lauderdale, FL
    Yep and amazing how it split shirt rom the sensor side.... but I fixed it and that's what counts
    1998 GTP Loudmouth
  10. #10 Re: Won't shift out of park
    Nov 2012
    Madison
    Pink, purple and green ones look cracked too.
  11. #11 Re: Won't shift out of park
    hes right, they are next to break.
  12. #12 Re: Won't shift out of park
    Mar 2013
    Fort Lauderdale, FL
    Yes I know, I touched them a little bit, but as long as they aren't yet, I'm not going to mess with them until they do snap of they do
    1998 GTP Loudmouth
  13. #13 Re: Won't shift out of park
    you know what they say,,,,,,,a stitch in time...
    i would have clipped and redone them all, no sense in doing a job 2 times.
  14. #14 Re: Won't shift out of park
    Mar 2013
    Fort Lauderdale, FL
    Well there's no guarantee they will snap but I agree, no job twice is fun but I don't mind working on the car
    1998 GTP Loudmouth
  15. #15 Re: Won't shift out of park
    Quote Originally Posted by crbquist View Post
    And you dealt with that for how long?
  16. #16 Re: Won't shift out of park
    Massachusetts
    Way too long lol
  1. Trans will not shift out of Park
    By GEE EX PEER in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2013, 02:52 PM
  2. Can shift from park with the car off
    By camopaint0707 in forum General Grand Prix Discussion
    Last Post: 07-19-2013, 06:13 AM
  3. cant shift out of park
    By gtpenthusiast in forum General Tech Discussion
    Last Post: 07-12-2013, 07:58 AM
  4. Key stuck and car won't shift out of park
    By chrisLB in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-01-2012, 11:47 PM
  5. Can't remove key or shift from park
    By airhead in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2012, 07:58 PM
