Thread: Which method to use for home made CAI?
Results 1 to 7 of 7
  1. #1 Which method to use for home made CAI?
    Sep 2013
    Dayton Oh
    So im about to make my CAI but i just wanted to see which way to go about it....
    Ive seen it been done two different ways 1. hook up pvc pipe with rubber grommet then put the filter on the other and and make a new hole for the MAF sensor or.......
    2. connect pvc to the stock intake tube and hook filter onto pvc.
    Just curious if either one makes a big difference?
    Question number two..... When you are taking out the air box does it come out rather easily or does it have a tray for the pcm? If so how do I go about mounting it?
  2. #2 Re: Which method to use for home made CAI?
    GT Level Member atj8's Avatar
    Midwest
  3. #3 Re: Which method to use for home made CAI?
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    My pvc goes right into the stock tube
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  4. #4 Re: Which method to use for home made CAI?
    May 2011
    Tampa FL near USF
  5. #5 Re: Which method to use for home made CAI?
    Apr 2011
    Vassar, Mi
    or you could always do the $50 4" fenderwell intake...
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  6. #6 Re: Which method to use for home made CAI?
    Sep 2013
    Dayton Oh
    Where did you get the aluminum piping for it?
  7. #7 Re: Which method to use for home made CAI?
    Apr 2011
    Vassar, Mi
  1. Home made intake
    By jman44 in forum Introductions/Noob Questions
    Last Post: 07-10-2013, 12:17 AM
  2. home made grills? post with your pics!
    By thomasd2010 in forum Visual/Body Modifications
    Last Post: 04-24-2013, 12:10 PM
  3. Home made Lo Hi fan Switch?
    By crock in forum General Tech Discussion
    Last Post: 10-17-2011, 05:44 AM
  4. home made down pipe.. possible?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2011, 09:54 PM
  5. home made pcm tray?
    By 01RedfireGT in forum General Tech Discussion
    Last Post: 04-29-2009, 06:26 AM
