Thread: Transmission temperature
Results 1 to 7 of 7
  1. #1 Transmission temperature
    Sep 2013
    Wauwatosa Wisconsin
    I have a 2008 Grand Prix gxp and after driving it for around 45 minutes my transmission temperature can reach up to 231 degrees. It shifts smoothly and the tranny fluid is red. Is this an issue that needs to be dealt with?
  2. #2 Re: Transmission temperature
    You need to get a trans cooler on there before you have to replace the trans.
  3. #3 Re: Transmission temperature
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    THIS!
    Mine used to range up to 210-215. I had it hotter once when I was in traffic for an hour trying to get out of Houston on a trip. I put a big B&M cooler on it and haven't been over 190 since. Typically I run 175 or so. That's been in 100+ degree weather since I added the cooler.
    If the fluid is regularly getting that hot, you likely need to drop the pan and replace the fluid. If you are that far in I would recommend doing a Transgo shift kit. I did that and have been very pleased with the results.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  4. #4 Re: Transmission temperature
    Max Cook
    Guest
    231 is a little high. 210-215 is completely fine though.
  5. #5 Re: Transmission temperature
    The hottest mine has ever got up to is 203 I have since done a pan drop filter change and shift kit now it's around 180 at the highest.
  6. #6 Re: Transmission temperature
    Sep 2013
    Wauwatosa Wisconsin
    The 231 was a one time thing that's just the highest it has reached after I beat on it a little bit. The average range is 210-215
  7. #7 Re: Transmission temperature
    Feb 2013
    Missouri
    Ideally, your transmission fluid should be 175*F, for every 20*F you increase the temperature, you cut the fluid's like in half. Normally, transmission fluid should last ~100,000 miles (@175*F of course).
  1. Temperature is all over
    By aray590 in forum General Tech Discussion
    Last Post: 03-13-2012, 10:01 PM
  2. Is this temperature normal?
    By Haulero in forum General Tech Discussion
    Last Post: 05-24-2010, 11:45 AM
  3. Temperature Problems
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-19-2010, 10:55 AM
  4. Transmission Temperature
    By TeeWX in forum General Tech Discussion
    Last Post: 03-10-2010, 12:14 AM
  5. Transmission temperature sensors
    By ronaldgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-03-2009, 01:32 PM
