Thread: head torque specs
Results 1 to 7 of 7
  1. #1 head torque specs
    Jun 2012
    Southern NJ
    Don't have a Torque-to-angle wrench, so what's the ACTUAL ft-lb torque spec for the heads, and what steps should it be done in?
  2. #2 Re: head torque specs
    Google it it'll pop up
  3. #3 Re: head torque specs
    Jun 2012
    Southern NJ
    Did that, couldn't find the relevant info.
  4. #4 Re: head torque specs
    If I remember when I get home on the computer I'll find it for you I have it saved from when I did my motor
  5. #5 Re: head torque specs
    If you're using TTY bolts, then you follow the TTY torquing procedure.
    If you don't want to do that, you need ARP studs which have a different torque procedure and value.
  6. #6 Re: head torque specs
    If you don't have an angle meter (like me) then know your angles. I bet you could print out a protractor pretty easy and use that to get the angles.
  7. #7 Re: head torque specs
    GTP Level Member tms8582's Avatar
    Washington Michigan
    +1
    3800 II - 2 Steps: 37FtLbs; +120deg
  1. torque specs off top of head and spark plug question
    By jman44 in forum Introductions/Noob Questions
    Last Post: 06-07-2013, 06:19 AM
  2. Replies: 7
    Last Post: 04-19-2012, 12:44 AM
  3. LIM torque specs
    By 98 GTPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2012, 11:25 PM
  4. torque specs LIM
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 11-11-2008, 08:31 PM
  5. i need torque specs
    By MTXGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-20-2008, 12:14 PM
