Thread: knocking noise when driving?
Results 1 to 11 of 11
  1. #1 knocking noise when driving?
    Apr 2013
    Michigan
    so whenever i hit a bump or something i hear a knocking noise from the rear driver side strut area, so i assumed it was the struts and had a friend replace both rear struts. long story short im still hearing the noise and have no idea what else to check, we took out the seats and interior panel in that area and cant find anything that seems loose, i have a coupe and the noise is like in the area of where the seatbelt comes out of on the side, if that makes sense, any ideas? i dont know what else to check and the noise is really obnoxious
  2. #2 Re: knocking noise when driving?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Strut mounts are probably shot, happened to me on my old GT. Change the struts for quick struts and call it a day.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  3. #3 Re: knocking noise when driving?
    Apr 2013
    Michigan
    Quote Originally Posted by WolvesSoulZ View Post
    already did that....well replica quick struts same thing just not monroe and half price lol but you get the point
  4. #4 Re: knocking noise when driving?
    check the rear sway bar and its bushings and end links and suspension bars back there.
  5. #5 Re: knocking noise when driving?
    Apr 2013
    Michigan
    oh and also replaced both sway bar links on each side since they were shot too
  6. #6 Re: knocking noise when driving?
    Max Cook
    Guest
    How do your rear strut towers look for rust?
  7. #7 Re: knocking noise when driving?
    Apr 2013
    Michigan
    Quote Originally Posted by Max Cook View Post
    not too good but not terrible
  8. #8 Re: knocking noise when driving?
    Max Cook
    Guest
    I mean I have the exact same issue and have never really figured it out. It didnt change at all when the struts/mounts/springs/swaybar etc all got fixed. Only thing I can think of is strut towers. Because my left side one has started rusting a bit amazingly (since its never seen more than half a winter). The right one is perfect though. I only get it fairly infrequently though. Used to get it very specific speeds.. But yeah... same exact thing.
  9. #9 Re: knocking noise when driving?
    both of you guys could try kicking the mufflers. make them move, see if you can duplicate the sound.
    i lost a front hanger, and then my add a hanger came loose and it was knocking around over bumps. i fixed all the hangers and its been quiet since. ( from the rear end) i still need new sway bar bushings for the front clunk i have.
  10. #10 Re: knocking noise when driving?
    Apr 2013
    Michigan
    yeah i guess i can give that a shot but it seems to high up to be from that, it sounds like its coming from the rear dash toward the strut, but im taking it to a shop this week and theyre gonna check it out for me
  11. #11 Re: knocking noise when driving?
    Apr 2013
    Michigan
    so i had a shop inspect the car and found that its because the towers are totally rusted out, along with the rest of the undercarriage and body down there, so looks like ill be selling it and looking for something else :/
  1. Knocking noise
    By TNTtransam in forum General Grand Prix Discussion
    Last Post: 09-14-2013, 10:13 PM
  2. Can't figure out knocking noise
    By indygrandprix in forum General Tech Discussion
    Last Post: 09-13-2012, 02:50 PM
  3. Knocking noise in rear?
    By BlueGXP in forum General Tech Discussion
    Last Post: 10-17-2011, 08:38 PM
  4. Knocking Noise While Braking
    By jonrk7 in forum Brakes/Suspension/Chassis
    Last Post: 10-15-2010, 02:14 PM
  5. knocking noise. HELP
    By GMtuner29 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 07:39 PM
