Thread: Dying Battery or Something More?
Results 1 to 16 of 16
  1. #1 Dying Battery or Something More?
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Previously when the battery in my car has decided to call it quits it simply stopped starting the car. It would be fine one day, and then the next it wouldn't come close to cranking the engine.
    Now over the past two weeks I have had the red battery light come on briefly after starting sometimes. It came on 2 days in a row, then I didn't see it for 6 days and then it went away yet again until yesterday (same driving patterns each day). When it has come on, it would go off around when the car warmed up. Today it stayed on.
    Car started right up, red light came on. Drove normally otherwise until about when the light would go off then the abs light joined in for no apparent reason. Shortly after the radio cut out and my phone stopped charging. Drove about 30 seconds more and radio came back along with the phone, red light went off, and abs light got twice as bright.
    Thing that I find interesting is that I had the A/C going at a fairly high fan speed which didn't miss a beat during all this.
    This my battery simply dying in slow motion or is there something more going on? Should I stop feeding it after midnight?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  2. #2 Re: Dying Battery or Something More?
    Have the battery and the alternator checked at your local parts store
    04 Comp G.
  3. #3 Re: Dying Battery or Something More?
    Newnan, GA
    ^ well duh, but I am curious as to how the abs ties in to this.
  4. #4 Re: Dying Battery or Something More?
    I see no mention on abs?
    04 Comp G.
  5. #5 Re: Dying Battery or Something More?
    Newnan, GA
    Quote Originally Posted by EJOUIE View Post
  6. #6 Re: Dying Battery or Something More?
    It's to early for this. Lol. I can tell you this if the prev gen is anything like the newer one..anytime the battery is having a issue it will cause a bunch of things like abs/TC, security to go off and on in the car.
    04 Comp G.
  7. #7 Re: Dying Battery or Something More?
    Newnan, GA
    That answered my question. That it is very possible that the abs light on is due to the battery and not the abs. Which removes quite a bit of worry.
  8. #8 Re: Dying Battery or Something More?
    Yea don't freak out lol should be a easy somewhat inexpensive fix. Let us know the outcome.
    04 Comp G.
  9. #9 Re: Dying Battery or Something More?
    check the battery voltage car off and on, check all grounds and battery connections, the cable to the alt too, make sure its tight, and a top the fuse box.
  10. #10 Re: Dying Battery or Something More?
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Sounds like an alternator to me. Get the alternator and battery tested. It could also be a battery cable.
    The ABS light and other things come up because the voltage drops below 9 volts long enough that those systems turn off.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  11. #11 Re: Dying Battery or Something More?
    Aug 2013
    Kitchener, Ontario
    As the previous have stated. When battery voltage drops, 'Battery Saver' kicks in systematically shutting down other components.
  12. #12 Re: Dying Battery or Something More?
    Newnan, GA
    Does battery saver affect A/C? Also when at 3500+ RPMS battery light would go off. ABS stayed on.
    I hooked up torque yesterday day and the voltage sat at about 11.5v until the coolant temp hit 160 or so (switched to closed loop) and then suddenly jumped to staying around 13.5v. All while at a very steady idle.
    I am pretty sure its the battery, but just noticing a couple odd things along the way that makes me wonder.
    How well do the auto craft batteries perform in our cars?
  13. #13 Re: Dying Battery or Something More?
    id think the alt is bad if the volts just jumped back to normal.
  14. #14 Re: Dying Battery or Something More?
    Oct 2012
    Houston, TX
    Everything you describe points to a failing alternator that cannot handle the load.
  15. #15 Re: Dying Battery or Something More?
    Newnan, GA
    Hmmm we got 2 votes for the alternator.
    Well I just got it tested, and it had 12.9v and 238 CCA.
    I replaced the battery. It was going on 4 years old anyways.
    We shall see how it goes starting in the morning as the old battery would not have an issue on the way home anyways.
  16. #16 Re: Dying Battery or Something More?
    Newnan, GA
    I think the issue was with the volt booster. I disconnected it, and halfway disconnected the gray part of it and then put it all back. Car has been good for 4 days now.
  1. new battery keeps dying
    By deuce in forum General Grand Prix Discussion
    Last Post: 10-22-2012, 06:23 AM
  2. Battery keeps dying...........PT 2
    By mallard22 in forum General Grand Prix Discussion
    Last Post: 05-11-2012, 11:30 PM
  3. Battery keeps dying...........
    Last Post: 05-08-2012, 11:37 AM
  4. Battery keeps dying (pics included)
    By genocide in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-26-2011, 12:16 PM
  5. battery dying
    By jaketrey32 in forum General Tech Discussion
    Last Post: 07-29-2009, 05:10 PM
