Thread: AC compressor
Results 1 to 8 of 8
  1. #1 AC compressor
    Dec 2012
    Lowell
    Anyone know what it will cost to have an Ac compressor in a 2000 grand prix gtp replaced?
  2. #2 Re: AC compressor
    I would say anywhere from $500 upwards of $1500 depending on where you go.
    If you do it yourself, the cost of the compressor, and its not that hard its like 3 bolts on the front then the nut holding on the line in the back.
  3. #3 Re: AC compressor
    Easy to do yourself and will only cost around $200 for everything
  4. #4 Re: AC compressor
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    I paid near 900 dollars about 5 years ago on my 97, compressor was leaking. They used GM compressor, refill ac etc. my ac works great since then, I have not had any problems.
  5. #5 Re: AC compressor
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I paid $50 and did it myself
  6. #6 Re: AC compressor
    Jan 2012
    Philadelphia
    junkyard for $25 at a u pull it, just have to hope its good
  7. #7 Re: AC compressor
    Delphi is cheap on Rockauto. For the charge, I'd suggest having the system vac'd down and filled properly. Also the orifice tube and accumulator aka drier should be replaced.
  8. #8 Re: AC compressor
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    I bought the AC compressor, Orifice tube, oil and Dryer online for about $150 somewhere. I do encourage you to do as Bill suggested with the evac and refill.
  1. WTB AC compressor
    By camopaint0707 in forum Wanted To Buy - Parts
    Last Post: 05-07-2013, 06:29 PM
  2. Compressor
    By InfidelRebel in forum General Tech Discussion
    Last Post: 08-13-2009, 01:41 AM
  3. ac compressor help
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2009, 02:28 PM
