Thread: Bad TCC Solenoid
Results 1 to 11 of 11
  1. #1 Bad TCC Solenoid
    GTX Level Member JDrach's Avatar
    Nov 2011
    Indiana
    Hey guys, I'm lead to believe my TCC solenoid is going bad. The car bogs down when it engages, timing drops by 5-7*, exhaust not depends/grumbles, and vibrates alot. I think it's also bad most importantly because it really likes to slam into engagement. I can be accelerating at 30
    mph or 45 mph and it will drop over 1,500 rpms pretty harsh into TCC lock. Accelerating is near impossible when its engaged and my timing can go to the teens easy with a little push of the accelerator. Only way around it is to have a light foot or disengage it and rev the engine up to accelerate before it slams back in.
    How will this ultimately effect the transmission? Sorry for the long post, feeling out of it n tired at the moment but it was on my mind.
    1998 Grand Prix GTP Daytona - CAI, XP Cam, Iceman tune, Speed Daddy Headers, 3.2 in pulley, Ported blower, Al 103's, 3in Catless DP, Transgo "shift kit", No resonator to Magnaflow Mufflers. 93K Miles
  2. #2 Re: Bad TCC Solenoid
    Nov 2011
    Indiana
    If this needs to be moved or is unclear to anyone, let me know. Trying to figure out more about this issue and what can happen cause of it.
  3. #3 Re: Bad TCC Solenoid
    Mine pretty much does the same. I just keep driving it.
  4. #4 Re: Bad TCC Solenoid
    Nov 2011
    Indiana
    Same. I thought it was maybe a bad circuit or wiring causing the TC to lock prematurely and is hard to break through. I can easily drop my timing from 23* when it locks down to around 10*'s before it unlocks and revs up to 2,500-3k. Only then do I gain my timing back. Not sure how much damage this can cause
  5. #5 Re: Bad TCC Solenoid
    SE Level Member A2tripp's Avatar
    Jun 2013
    Upstate ny
    I got the same issue but not as severe. There is a testing procedure to determine what part of the system is screwing up. I'll try to find the link for you and post.
    like dsmuts I have been ignoring it too, but makes me feel like I'm driving a pos.
    99 gtp
    04 powerstroke
  6. #6 Re: Bad TCC Solenoid
    Jun 2013
    Upstate ny
    This isn't the link I was thinking of but it does have the procedure
    Diagnosing GM Converter Lock-Up Problems
    There's a forum that had someone with a gp doing the procedure but
    99 gtp
    04 powerstroke
  7. #7 Re: Bad TCC Solenoid
    Nov 2011
    Indiana
    I might disconnect the TCC solenoid if I can. iIRC I read its on top of the trans under the air box for the intake. I also think it maybe be fr ZZP's tune and some settings they've might've altered? Unsure.
  8. #8 Re: Bad TCC Solenoid
    The Boss Iceman6669's Avatar
    Jun 2011
    Mine acts up badly.. Sometimes even causes KR. Either have your tune adjusted or have it replaced.
    2011 F-150 Yote powered
  9. #9 Re: Bad TCC Solenoid
    Nov 2011
    Indiana
    Ya ill have to just keep driving accordingly to get around it. Ill have Paul look at the trans settings and see if anything could be changed or if its indeed a mechanical problem.
  10. #10 Re: Bad TCC Solenoid
    Jun 2013
    Upstate ny
    Chances are its a mechanical problem. A couple hours of home diagnostics will tell you for sure.
    let us know what you find out
    99 gtp
    04 powerstroke
  11. #11 Re: Bad TCC Solenoid
    Jun 2011
    Even if it is a mech problem, they can adjust the point at which the TCC unlocks and it will help/correct the chugging.
  1. BBV solenoid
    By blakgtp in forum General Grand Prix Discussion
    Last Post: 07-31-2012, 10:14 PM
  2. TCC solenoid bad?
    By rah575554eg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2011, 07:13 AM
  3. Epc solenoid help!
    By WhiteGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-27-2009, 12:31 PM
  4. bbv solenoid
    Last Post: 03-11-2009, 01:42 PM
