Thread: Engine chugging/ multiple cylinder misfires??
Results 1 to 6 of 6
  1. #1 Engine chugging/ multiple cylinder misfires??
    Aug 2013
    Caledonia, MI
    A few days ago my "check engine" light came on, a day later the car started running very roughly and "chugs/bogs down" when accelerating. The car runs somewhat smoothly when idle, but as soon as I step on the gas, it has no power and I can feel that not every cylinder is firing. I did some research online and everything pointed to the Crankshaft Positioning Sensor (apparently its not uncommon for these things to go out on grand prix). So I replaced that. Did not even help with the problem. Now my car barely runs, the scan tool keeps providing the code "p0300- multiple cylinder misfires", and the temperature gauge barely reads, and the car runs hot. MY father and I are pretty car savvy, but we have NO IDEA what it could be. And i don't have the funds to have it towed to a shop and pay them to dink around for hours, while i pay them hundreds/thousands of dollars, or to replace everything under the hood myself. PLEASE HELP ME!!
  2. #2 Re: Engine chugging/ multiple cylinder misfires??
    Plugs
    Wires
    Vacuum leak
    Tune-up in general.
    Get that done.
    Could also be a clogged cat.
    Most car savvy people would do all that first
  3. #3 Re: Engine chugging/ multiple cylinder misfires??
    A code P0300 may mean that one or more of the following has happened:
    • Faulty spark plugs or wires
    • Faulty coil (pack)
    • Faulty oxygen sensor(s)
    • Faulty fuel injector(s)
    • Burned exhaust valve
    • Faulty catalytic converter(s)
    • Stuck/blocked EGR valve / passages
    • Faulty camshaft position sensor
    • Defective computer
  4. #4 Re: Engine chugging/ multiple cylinder misfires??
    Defective computer.
    IT'S GOT A VIRUS!
  5. #5 Re: Engine chugging/ multiple cylinder misfires??
    Eh i just copied and pasted the info from obd-codes
  6. #6 Re: Engine chugging/ multiple cylinder misfires??
    Donating Users
    Aug 2013
    Michigan, USA
    New spark plug and wires, around $75 for the full set of good brand.
    Check fuel pressure. If it's weak, check the pump, power to pump, fuel line, and filter.
  1. multiple cylinder firing
    By wontownapontiacagain in forum Introductions/Noob Questions
    Last Post: 03-20-2013, 11:22 PM
  2. Multiple Misfires After Radiator Install
    By sdavis11b in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2013, 03:15 PM
  3. 97 gtp multiple cylinder misfire help.
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2012, 11:40 AM
  4. multiple misfires
    By rsookar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2010, 04:18 PM
  5. multiple misfires out of now where
    By DunriteDiesel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2008, 10:51 AM
