Starting with I have a 2000 grand prix 4 door. This is what I've done. Backup lights and trunk release I know are on fuse 27 under the hood. Fuse is good. Changed the park/neutral safety switch thinking that might be the problem, it wasn't. Took the trunk release solenoid off and hooked it up to the battery and it worked. Checked the bulbs in the backup lights and they were good. When I read volts to the trunk release, testing the connector without the solenoid hooked up. It reads 11.24 volts when the button is pushed in the glove box. When connected to the solenoid it reads nothing. Solenoid works when hook directly to the battery. Moving on the the backup lights. Volts read 0 and .24 when the brake lights is pushed and same reading when it is put into reverse. Moving on to the fuel level reading, I just cleaned the connection underneath the car by the fuel tank and that did not help. Any help here would be great. Thank You
