Thread: 2001 Grand Prix GT - RPM gauge and traction problem...
Results 1 to 10 of 10
  1. #1 2001 Grand Prix GT - RPM gauge and traction problem...
    Aug 2012
    Prestonsburg, KY
    2001 Grand Prix GT, 3.8 motor. My son was driving it (maybe that's!
    the problem!) and he said he heard a small click. Afterwards, the Tach
    goes to 0, and the traction light stopped working.
    What's the most likely cause - fuse or sensor, or something like that?
    Thanks all.
  2. #2 Re: 2001 Grand Prix GT - RPM gauge and traction problem...
    Normally when the tac goes to zero its a common crank sensor issue.
    Does the tac work after he shut the car off and turned it back on??
  3. #3 Re: 2001 Grand Prix GT - RPM gauge and traction problem...
    Aug 2012
    Prestonsburg, KY
    Yes, he said it all came back on after he turned the car off overnight and started
    it the next morning. It also hasn't done it since.
    So that's the crankshaft sensor?
    How hard is that to put on (and is it very expensive)?
    Thanks!
  4. #4 Re: 2001 Grand Prix GT - RPM gauge and traction problem...
    Aug 2012
    Prestonsburg, KY
    Bumping this thread a bit...
    Some friends of my son told him to change the cam shaft position sensor first.
    Well, we did. It wasn't hard, but it also didn't fix the problem. Right now, he
    can start the car, starts fine, drive it, and only sometimes, when it acts up, the
    tach will drop to zero, the traction warning light comes on, and any time he stops
    (red lights, stops ect) the car will die if he doesn't keep it revved up. It's running
    smooth though, no roughness or anything like that.
    Still probably the most likely culprit is the crank shaft sensor?
    Thanks, and still wondering how hard this is to replace. I tried some searches,
    looks like its fairly involved, with having to use some kind of puller to remove
    stuff to get to the sensor. Do you also have to have a press to put it back on?
    Thanks gang.
  5. #5 Re: 2001 Grand Prix GT - RPM gauge and traction problem...
    Aug 2012
    Prestonsburg, KY
    Well, had some other people tell us that it could be something in the instrument cluster, as well as some black box on the side of the transmission that would cause it to do the same thing.
    I'm leaning towards the crankshaft position sensor, but does anyone have any experience with the above?
    Thanks!
  6. #6 Re: 2001 Grand Prix GT - RPM gauge and traction problem...
    SE Level Member Yamahakid88's Avatar
    Jun 2013
    Illinois
    Heres a nice write-up by BillBoost37. http://www.grandprixforums.net/how-r...sor-60906.html
    Also a video I found for ya..
    How to replace a crankshaft sensor on a grand prix gtp - YouTube
    As for the sensor, its not expensive 30$-50$ on ebay
  7. #7 Re: 2001 Grand Prix GT - RPM gauge and traction problem...
    Jul 2012
    Chicago
    Sounds like a typical crank sensor issue. Usually tach misbehaviour gives it away.
    -Carl
  8. #8 Re: 2001 Grand Prix GT - RPM gauge and traction problem...
    Aug 2012
    Prestonsburg, KY
    Thanks guys - on my son's next day off, we're gonna give it a shot.
    Much appreciated!
  9. #9 Re: 2001 Grand Prix GT - RPM gauge and traction problem...
    Aug 2012
    Prestonsburg, KY
    Update:
    We finally got a day off together, along with some good weather (well, a little
    hot - it busted 90+ here today), so we tackled replacing the CPS.
    Everything went just like the guide and video showed until we hit the big 24mm
    center bolt. Man, that sucker was on there hard. We broke a few tools and things
    trying to anchor it down and never could break the bolt loose. We didn't have
    access to an airgun/wrench.
    So we finally got in touch with a local auto parts store owner that we know pretty
    well (he also has a garage) and he told us to pull the fuel pump relay, start the
    car and run it till it died. Then, using a 1/2" breaker bar with the 24mm socket,
    put it so it catches the frame of the car, after noticing which way the dampener
    turns (it's clockwise). Then, just touch the key and "hit" the bolt like that. Took
    about 3 tries but I'll be danged if it didn't work. 3rd try and the bolt was loose
    enough to unscrew by hand.
    I had bought the GM 3800 specific bolts from that Amazon link that another
    guy posted so the puller part went great. No problems there. Even managed
    to get that plastic housing off without breaking it.
    Everything else went fine after that. Of course, he'll have to run the car for a few
    days just to make sure it's all good, but it's all done now.
    Thanks to everyone for the advice and links to guides and videos. Really awesome
    stuff and a great help.
  10. #10 Re: 2001 Grand Prix GT - RPM gauge and traction problem...
    thats called the redneck starter trick to remove the balancer bolt. works every time it seems. you can also pull the ignition fuse. or pull the plug wires. to keep the engine from starting.
  1. Temperature gauge not working on 2001 Grand Prix SE
    By paulk in forum General Grand Prix Discussion
    Last Post: 07-31-2012, 09:40 AM
  2. 2001 grand prix gt wireing problem
    By nascartech in forum General Tech Discussion
    Last Post: 10-08-2010, 10:20 PM
  3. 2001 grand prix problem list
    By 01gt ryan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2010, 01:40 AM
  4. MAF problem 2001 Grand Prix GT V6
    By hurricanejt in forum General Tech Discussion
    Last Post: 07-13-2010, 11:04 AM
  5. 2000 grand prix traction control problem
    By marckub203 in forum Introductions/Noob Questions
    Last Post: 08-19-2009, 10:02 PM
