Thread: Tinted Boost Gauge Dimming
Results 1 to 14 of 14
  1. #1 Tinted Boost Gauge Dimming
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    I'm installing my boost gauge soon and I want to hook up my gauge to the dimmer wire for my cluster and all the other lights on the dash. Because the cluster is light sensitive it shouldn't matter though, right? Because all the stuff like the dic stay lit up all the time, so shouldn't the gauge do the same?
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  2. #2 Re: Tinted Boost Gauge Dimming
    Banned
    Jan 2013
    Colorado
    Try an autometer dimming switch. I plan on doing the same thing.
  3. #3 Re: Tinted Boost Gauge Dimming
    Dec 2012
    Where 4T65E's were born
    Quote Originally Posted by ILoveGM View Post
    I'm not exactly sure what you're asking. At first it looks like you want to hook it up to the dimmable lights on the dash so it dims with the dash. (not good since they're not going to be the same brightness, you may want the boost gauge dimmer but the dash brighter. You could get away with it by installing a resistor to match them though/tinting)
    Then it looks like you want to hook it up to the dic since it doesn't dim, but stays on all the time when the key is on.
    Sold.
  4. #4 Re: Tinted Boost Gauge Dimming
    Aug 2012
    I'm not exactly sure what you're asking. At first it looks like you want to hook it up to the dimmable lights on the dash so it dims with the dash. (not good since they're not going to be the same brightness, you may want the boost gauge dimmer but the dash brighter. You could get away with it by installing a resistor to match them though/tinting)Then it looks like you want to hook it up to the dic since it doesn't dim, but stays on all the time when the key is on.
    Hard for me to explain. Lol
  5. #5 Re: Tinted Boost Gauge Dimming
    The Boss Iceman6669's Avatar
    Jun 2011
    If you want the gauge to dime hook the dimmer wire up to any light that come on with your head lights. Then when you flip on head lights the gauge will dim.
    2011 F-150 Yote powered
  6. #6 Re: Tinted Boost Gauge Dimming
    GTX Level Member blackflag's Avatar
    Virginia
    are you t/c? if not your wasting money...
  7. #7 Re: Tinted Boost Gauge Dimming
    Aug 2012
    Quote Originally Posted by BlackFlag View Post
    Read my sig. lol. It's a boost/vac actually. Guess I should have included that
  8. #8 Re: Tinted Boost Gauge Dimming
    Virginia
    i just read your sig, you are absolutely wqsting money.
  9. #9 Re: Tinted Boost Gauge Dimming
    I did this once upon a time. To be fair, I took the easy way out.
    Just find the two wires on the back of the dimmer switch that gets you a ground and a variable positive output from the switch. Cut, solder, and seal.
    It's visible during the day, because there's sunlight. At night it's visible because it's backlit.
    If you really want it on all the time, turn your parking lights on.
    Or just hook a pot inline with the lightbulb. But then you have to go through the hassle of finding a knob for it, and a location to mount it.
  10. #10 Re: Tinted Boost Gauge Dimming
    Aug 2012
    Why? Because I'm doing something to MY car? It doesn't matter what anyone does to their car. Everything is a waste of money when it comes to cars unless it's routine maintenance. Cars are a poor investment, whether it is performance parts or for looks. I'm in the process of dressing my car up. My money. My choice. Simple as that.
  11. #11 Re: Tinted Boost Gauge Dimming
    Virginia
    you are wasting your money..... simple for anyone knowledgable to see
  12. #12 Re: Tinted Boost Gauge Dimming
    Virginia
    basically your buying your boost gauge for looks. therefore, (excuse me for being a richard) RICE.
  13. #13 Re: Tinted Boost Gauge Dimming
    Aug 2012
    Oh well. I'm not here to please anyone. To each their own. I'm a junior in high school. I need as much money as possible. So tiny things here and there are fine with me.
  14. #14 Re: Tinted Boost Gauge Dimming
    Jun 2011
    Needle boost gauge is easier to read then the AF.
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
