Thread: Got some codes read, not sure what they mean.
Results 1 to 20 of 20
  1. #1 Got some codes read, not sure what they mean.
    Jul 2013
    Utah
    Car threw some codes today, had them read, couple were no big deal, but these two caught my attention.
    Code P1811
    Definition: Maximum adaptive and long term shift.
    Explanation: The ECM has detected the shift execution time has exceeded the required shift time period.
    Probable Cause:
    1. Trailer towing may falsely set code
    2. Low line pressure - plugged filter or pump
    3. Computer relearn may be required
    Code P0420
    Definition: Catalyst eficiency low-bank 1
    Explanation: The oxygen sensors monitor the Catalytic Converters ability to store oxygen.
    Probable Cause:
    1. Catalytic converter defective (failure possibly due to #2, 3, or 4)
    2. Engine misfire or running condition
    3. Large Vacuum Leak
    4. Engine oil leakage into exhaust-valve guide seals, piston rings
    OK, how do I go about figuring out the actual reasons for these codes being thrown. Particularly the second one. Could code P0420 be the cause of some overheating problems I've been having? Not sure how to go about doing these step by step...
    Thanks for any help
  2. #2 Re: Got some codes read, not sure what they mean.
    gardner,mass
    plugged cat? get under your car while its cold and tap on the cat and see if it rattles
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  3. #3 Re: Got some codes read, not sure what they mean.
    First code is a transmission code, they make a shift kit that helps make that one go away.
    Second code likely mean the cat converter is bad, it can no longer do its job as good as the computer wants.
  4. #4 Re: Got some codes read, not sure what they mean.
    Jul 2013
    Utah
    OK I'll tap on the cat when it gets cold. Would a bad cat cause overheating?
  5. #5 Re: Got some codes read, not sure what they mean.
    Engine overheating, no.
    It would just make the car sluggish and overtime once it was fully plugged you couldnt even drive the car because it can't get the exhaust out.
  6. #6 Re: Got some codes read, not sure what they mean.
    gardner,mass
    by overheating you meen?
  7. #7 Re: Got some codes read, not sure what they mean.
    Jul 2013
    Utah
    Car Maintenance : Can a Bad Catalytic Converter Make a Car Overheat? - YouTube
    This guy says clogged or bad catalytic converters can cause overheating...
    Me and a friend have the exact same car, we will both be driving around, short drives, long drives, etc. and my vehicle gets MUCH hotter than his, my engine bay feels hotter and my car runs hotter. I'm thinking the backup of the heat from the exhaust is a pretty decent explanation as to why it's all so hot. Does it cost a lot to replace a cat?
    As far as the shift kit goes that you mentioned, where can I pick one up? And is it a relatively easy self install?
  8. #8 Re: Got some codes read, not sure what they mean.
    May 2013
    Philadelphia
    I got that same code p0420 i used that cataclean treatment it help a little the check engine light went out and has not been back on but when i hooked up my scan tool the p0420 was still stored took the car my mechanic he confirmed the cat is going bad the estimate was $1000 is that to much or about right? they are ordering a direct fit cat from the dealership (2005 grand Prix GTP under 120,000 miles) Thanks guys
  9. #9 Re: Got some codes read, not sure what they mean.
    SE Level Member Ohara's Avatar
    Mar 2013
    PA
    Quote Originally Posted by cease1981 View Post
    $1000? You could save a lot of money doing it yourself if you have the means to do so. I replaced mine back in April, but my buddy has a lift in his garage. Took an hour if that. Even if you can't do it you could just buy one for a lot cheaper and have your mechanic install it. Here's the one I got. More Information for EASTERN CATALYTIC 50358 Save money, don't buy from the Stealership.
  10. #10 Re: Got some codes read, not sure what they mean.
    A cat from a dealer is like 650-800 bucks I bet, very $$$$$$$.
  11. #11 Re: Got some codes read, not sure what they mean.
    gardner,mass
    i sell the walker direct fit for $287 cash customer. 2.50 for one gasket 8.29 for the other. Probly take someone without exp a couple hours. Might need new bolts for after cat and a torch to get the o2 sensor off or replace it for $55 You will have to probly rock the engine forward by unhooking the dogbone mounts in front and i suggest a ratcheting wrench or you might be able to get them from the bottom with a long extention but i usually cant get the torque on them needed and the right one is hard to get at without a u-joint on the socket.
  12. #12 Re: Got some codes read, not sure what they mean.
    May 2013
    Philadelphia
    Quote Originally Posted by Ohara View Post
    Thanks that's exactly what I'm going to do, do you know if the cat come with the gaskets or do i have to buy that separately
  13. #13 Re: Got some codes read, not sure what they mean.
    Mar 2013
    PA
    Mine came with front and rear gaskets.
  14. #14 Re: Got some codes read, not sure what they mean.
    Jul 2013
    Utah
    Where I live they don't care about emissions. Well, I shouldn't say they don't care, but they don't check them and aren't required for a yearly inspection. Gonna just grab a hacksaw in the morning and cut the damn thing off.
  15. #15 Re: Got some codes read, not sure what they mean.
    I wouldnt if I was you.
    Unless you want the car to get some real crap tastic mpgs. No cat and your car will just dump fuel likes its pouring it down a drain.
  16. #16 Re: Got some codes read, not sure what they mean.
    May 2013
    Philadelphia
    Thanks a lot by taking your advice i saved a lot of money i got the exact same catalytic converter you bought $192 after tax and $80 to have it installed
  17. #17 Re: Got some codes read, not sure what they mean.
    Jul 2013
    San Bernardino,Ca
    Where do you suggest getting a cat from thats legal in California?
  18. #18 Re: Got some codes read, not sure what they mean.
    a walker cat and down pipe should be ok. its a direct factory replacement.
  19. #19 Re: Got some codes read, not sure what they mean.
    Banned
    Oct 2013
    Moorhead, MN
    People talk about emissions testing. First I ever heard it in my 30 years was about a month ago.
  20. #20 Re: Got some codes read, not sure what they mean.
    Mar 2013
    amherst
    I gained 3-4 mpgs with no cat and no 02s , maybe I got lucky ?
  1. cant read cd's
    By sirricealot in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2012, 11:52 AM
  2. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  3. Scan tool to read 03 GTP ABS Codes
    By ronmexico in forum General Tech Discussion
    Last Post: 04-12-2012, 05:54 PM
  4. CODES finally read.heres what PEP BOYS wants to charge!!
    By spider4 in forum General Tech Discussion
    Last Post: 12-30-2011, 04:00 PM
  5. Can I read a dhp with a hpt?
    By TDCRacing in forum PCM Tuning
    Last Post: 04-09-2008, 03:30 PM
