Car threw some codes today, had them read, couple were no big deal, but these two caught my attention.
Code P1811
Definition: Maximum adaptive and long term shift.
Explanation: The ECM has detected the shift execution time has exceeded the required shift time period.
Probable Cause:
1. Trailer towing may falsely set code
2. Low line pressure - plugged filter or pump
3. Computer relearn may be required
Code P0420
Definition: Catalyst eficiency low-bank 1
Explanation: The oxygen sensors monitor the Catalytic Converters ability to store oxygen.
Probable Cause:
1. Catalytic converter defective (failure possibly due to #2, 3, or 4)
2. Engine misfire or running condition
3. Large Vacuum Leak
4. Engine oil leakage into exhaust-valve guide seals, piston rings
OK, how do I go about figuring out the actual reasons for these codes being thrown. Particularly the second one. Could code P0420 be the cause of some overheating problems I've been having? Not sure how to go about doing these step by step...
Thanks for any help
